MQX_USE_LOGS - error log to file
2,924 次查看
jasonscott
I was wondering if there was an example of how to use the error log and save it to a file on an SD card?
I am running MQX 4.2.
I looked under that directory for an example, but nothing jumped out at me.
Anyone have any references i can look at?
Jason
标记 (2)
2,749 次查看
danielchen
Hi Jason:
I would suggest you  refer to the web_hvac demo
Freescale_MQX_4_2\demo\web_hvac
You can see there is a logging task, it can store log information on a USB Memory Stick
2,750 次查看
danielchen
Hi Jason:
2,749 次查看
jasonscott
Hi Daniel,
Thanks for that info!
I have a followup question about the TAD pointer.
Is there an easy way to check what line of code or instruction that the pointer is pointing to?
I am basically trying to find out where this occurred.
Normally id look at the map file to figure this out, but if it occurs in kernel space i am not sure how to track it down.
Jason
