Hi @davidzhu
Hi @davidzhu :
k66_180 is supported in MQX v5. MQX v5 is a continuation of the MQX classic product available under low-cost commercial terms. MQX v4.2 is no longer available & superseded by V5. MQX v5 is backward compatible with MQX classic.
If you need to port k66 to MQX 4.2 by yourself, please refer to the MQX BSP porting guider.
C:\Freescale\Freescale_MQX_4_2\doc\mqx\MQX_BSP_Porting_Guide.pdf
C:\Freescale\Freescale_MQX_4_2\doc\mqx\MQX_BSP_Porting_Example_User_Guide.pdf
