My goal is to migrate our product from mK64 to mk66. But MK66 is not available in MQX 4.2 package.
could you please let me know what required to change?
Thank you very much
Solved! Go to Solution.
Hi @davidzhu
Hi @davidzhu :
k66_180 is supported in MQX v5. MQX v5 is a continuation of the MQX classic product available under low-cost commercial terms. MQX v4.2 is no longer available & superseded by V5. MQX v5 is backward compatible with MQX classic.
If you need to port k66 to MQX 4.2 by yourself, please refer to the MQX BSP porting guider.
C:\Freescale\Freescale_MQX_4_2\doc\mqx\MQX_BSP_Porting_Guide.pdf
C:\Freescale\Freescale_MQX_4_2\doc\mqx\MQX_BSP_Porting_Example_User_Guide.pdf
Hi @davidzhu
Hi @davidzhu :
