Inter-processor communication (IPC) over CAN Bus
2,131 次查看
amleng
Is it possible to have IPC over CAN bus. In MQX Reference  manual I found _ipc_add_io_ipc_handler() can get  IO_CAN_COMPONENT as the parameter component but I didn't see any example code. In addition, #define
IO_CAN_COMPONENT is commented in psp library.
1,715 次查看
DavidS
Hi Sina,
The IPC examples we have are for serial and Ethernet.  Any hardware interface can be ported to.  We just haven't ported the IPC example code to every possible peripheral.
Hopefully our examples will allow you to port to a CAN interface.
David
1,716 次查看
DavidS
Hi Sina,
David
