How to use Flashx in MQX4.1
1,681 次查看
小勇邹
How to use Flashx in MQX4.1?
I do not know how to use the API in the Flashx. Is there any source code example?
1,434 次查看
daweiyou
Hi:
The sample code is located in:
Freescale_MQX_4_1\mqx\examples\flashx
Dawei You(尤大为)
Field Application Engineer
Freescale Semiconductor (China) Ltd - Nanjing Branch.
6 回复数
1,435 次查看
daweiyou
Hi:
Dawei You(尤大为)
1,434 次查看
小勇邹
Is it necessary to erase the flash before writing data to the flash?
I do not find the erasing command before writing data to the flash in the examples(Freescale_MQX_4_1\mqx\examples\flashx).
1,434 次查看
daweiyou
Hello Robin:
Yes, it need erase before write;
But BSP driver have done these works.
Dawei You(尤大为)
1,434 次查看
小勇邹
Hello Dawei,
The <K64 Sub-Family Reference Manual> describes that "the smallest portion of the program flash memory that can be erased is 4KB".If I only
write 32 Bytes data,it will affects the data in the 4KB memory.Is it right?
1,434 次查看
daweiyou
Yes, The flashhx driver copy old data and merge new data, erase whole sector and re-write the sector;
Dawei You(尤大为)
1,434 次查看
小勇邹
I get it.Thank you.
