FILE is defined in two header files
1,682件の閲覧回数
mrupp_viatechno
I am using CodeWarrior 10.6 with MQX 4.0 and am having a problem where FILE is defined in two header files.  It is defined in file_struc.h (ARM_EABI_Support) and in fio.h (psp).  I have tried various defines such as MQX_SUPPRESS_FILE_DEF and _AEABI_PORTABILITY_LEVEL but these just result in different redefine errors.
Any ideas on how to fix the multiple definitions?
1,573件の閲覧回数
mrupp_viatechno
The problem was including stdio.h.  Removed '#INCLUDE <stdio.h>' and problem solved and program builds.
1,574件の閲覧回数
mrupp_viatechno
