ERROR: Can't open USB device!!!
2,372 次查看
llliu
      I use NXP DDR Test  Tool to test  MX7D .The TARGET has been choosed MX7D.
But the result ERROR: Can't open USB device!!!.
Why???
标记 (1)
1,814 次查看
Yuri
 I.MX7 must be in Serial Downloader mode (BOOT_MODE[1:0] = 01).
Also it makes sense to check in i.MX7 is working. Use chaper 4 (Avoiding board bring-up problems)
of the Hardware Development Guide
http://www.nxp.com/assets/documents/data/en/user-guides/IMX7DSHDG.pdf
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
1,815 次查看
Yuri
Yuri
button. Thank you!
