Connect() non-blocking?
4,388 次查看
vespaman
While there are general non-blocking support in RTCS, I cannot find any information, also connect() has this support.
I'm looking into having a go at RTCS for my project, and are trying to find the disadvantages for doing this..
Can anyone enlighten me?
 Thank,
  Micael
标记 (1)
2,549 次查看
anthony_huereca
In the connect() section of the RTCS User's Guide, it states:
"This task blocks, until the connection is accepted, or until the connection-timeout socket option expires."
The manual can be found in the docs directory in your MQX installation, or on the web here
Hopefully that answers your question
2,550 次查看
anthony_huereca
2,549 次查看
Phil_D
Hi Micael,
Is this the info you are looking for?
http://www.freescale.com/files/32bit/doc/support_info/ColdFire_Lite_Doc.zip?fpsp=1
Phil
Message Edited by Phil_D on 2009-06-22 09:03 PM
2,549 次查看
vespaman
Hi Phil,
Thanks! But actually, I think the zip you linked to, are for Freescales Interniche-Lite package, which is different from the MQX, as far as I understand.
I had a look at that before, but it seamed too limited for me, and I was not sure about ongoing support/update with it. I hope, with MQX, that Freescale has a more robust plan, and also longer term committment with MQX, otherwise, many of us better turn to other solutions (open source or commercial).
 Micael
