mpc5744p bootloader
mpc5744p bootloader
1,798 次查看
yanzc
    hi! due to the need of work,I want to finish the mpc5744p bootloader in very short time.
  1. I read the document of AN5319(serial bootloader for MPC5748G)before, and I found that the demo use ghs ide not S32. So there will be some different palces on the configuration.
  2. I wonder if it's the same procedure to program or erase flash between mpc5744p and mpc5748g.
  3. Can you teach me how to write the mpc5744p BootLoader step by step. thanks~~~~~~
1,461 次查看
petervlna
1. There is only GHS bootloader example.
2. Yes, the procedure for flash operations are same. Flash driver can be found here:
https://www.nxp.com/downloads/en/device-drivers/C55_JDP_SSD.exe
3. Maybe someone from community can help you.
Peter
