microcontroller MPC5748G is running while in debugging mode
FAISAL0323
Hi experts:
I have a problem with debugging. please help me, need your help!
I am using MULTILINKER UNIVERSAL debugger for debugging purpose. I have one breakpoint in project. When program hits that breakpoint. the program halts, while microcontroller is running  full code in background. After I start doing step over from breakpoint program halts again and the console window always show following prompts, so my memory and Expression can not be read successfully. After that I am unable to debug again.
Thanks in advance
lukaszadrapa
the debugger obviously tries to read a data (peripheral registers) which are not available. You can take a look at:
https://community.nxp.com/t5/MPC5xxx/Error-Enabling-the-Periph-Clock-MPC5748G/m-p/930660
Lukas
