Test of Error on Flash read and write
20Sidar04
Dear Mr. / Mrs.
How can i simulate error on Flash like that mentioned belove?
Read Voltage Error
Read Reference Error
Read-While-Write Event Error.
Best Regards.
lukaszadrapa
I can't see a way how to simulate/inject first two errors.
To trigger RWW error, you can start a flash operation (like program or erase) on certain block. At the same time, you can read data from the same partition. This will trigger machine check error and RWE in MCR register will be set.
Lukas
20Sidar04
Thank you, Lukasz your support.
lukaszadrapa
Lukas
