flash programming for MPC5748G
1,947 次查看
huqiang
Was it possible that I use the S32 design studio and PE to do flash programming for MPC5748G?
I know that Lauterbach T32 can be used to do this, but how about using the S32 desgin studio and PE?
I need to put a "x.elf" file to a specified memory address。
Hu
1,522 次查看
petervlna
Yes, you can use S32DS with PE Micro. There is no issue and it is commonly used.
However for serious development I recommend Lauterbach.
Peter
1,522 次查看
huqiang
Do you have any instruction about how to do this?
Where can I configure the specified memory address?
I only have the "x.elf" file instead of making a project and debugging in S32 DS.
How can I directly put "x.elf" file to a specified memory address.
Hu
1,522 次查看
stanish
Hi Hu,
Please see this document:
https://community.nxp.com/docs/DOC-332252
Hope it helps.
Stan
