Using the RAppID Bootloader to Program MCU without Hardware Configuration
1,225件の閲覧回数
gsengineering
I am looking to be programming a MPC5607B on a custom board using the RAppID bootloader. My main goal with using the bootloader would be to disable censorship on the MCU before reprogramming it. I want to confirm that no other hardware configuration, such as configuring the FAB and ABS pins, would be required. I'll be using CAN to program the MCU.
Thanks for the help.
1,157件の閲覧回数
lukaszadrapa
you need to configure only FAB and ABS pins. Other HW configurations are not needed.
Lukas
