UTEST region problem (mpc5744p)
xiaobozheng
 HI:
       we need to read utest region (0x00400060) to test flash ecc error path, but there is two problem,
1:  when the program jump to main(), we found there is a error in MEMU ,174663_174663.pngpastedImage_1.png
2:  when we read the address (0x00400060), the program will collapse, why this is happen?
 thanks !
davidtosenovjan
I have recently shared example code for this. You may see it here:
https://community.nxp.com/docs/DOC-333754
Hope it helps
