Signal Processing on MPC5674
3,484 次查看
dpastl
Hi There,
I'm investigating adding signal processing to our product to attempt to reduce time spent on calculations.  I've been reading around on the SPE2 module for the MPC5674F but I can't figure out where to start.  Are there any libraries available, or application notes, on how to start using the SPE2 module with C?  What I'm really curious is, do I need to add a special library or if not, what header do I include?
Thanks!
David
3,359 次查看
davidtosenovjan
Yes, it should work as SPE units is backward compatible.
3,359 次查看
davidtosenovjan
Following two libraries could be useful for you. These package contain a software and descriptive documents.
MPC55xx SPE DSP Library 1:
http://www.nxp.com/files/microcontrollers/software/app_software/code_examples/MPC55xx_SPE_DSP_Librar...
MPC55xx SPE DSP Library 2:
Also pay attention to following appnote
Improving DSP Performance Using Efficient SPE Coding (including FIR example):
http://www.nxp.com/files/microcontrollers/doc/app_note/AN3733.pdf
3,359 次查看
dpastl
Will the MPC55xx libraries work for a 56xx processor?
3,360 次查看
davidtosenovjan
