Shutdown self-test problem!
3,179件の閲覧回数
xiaobozheng
Dear all:
         we have found a strange situation, we test our source code on board with different versions of  MPC5744P, the result is different .
       our program can not working normal on our board (with chip mask IN15P), there always have three low blocks are failed .  But it can work on our old board (with chip mask IN65H) .
 the result is still like this on our B2 sample (chip mask IN15P):
but the results on our old sample - B1(chip mask IN65H):
why this is happen ? how can we fix it ?
this is our shutdown self-test code:
void ShutDownSelfTest()
 if (STCU_MBELSW!=0x07ffffff)
     Pre_ShutDownSelfTest();
     ShutDownSelfTest_Init();
 sys_check_stcu_shutdown();
/*         check  shutdown selftest   status                              */
static void sys_check_stcu_shutdown()
 /*Shutdown LBIST End Flag*/
 while(STCU_LBESW !=0x0000000f );
 /*Shutdown LBIST Status*/
 while(STCU_LBSSW != 0x0000000f);
 /*Shutdown MBIST End Flag*/
 while (STCU_MBELSW !=0x07ffffff);
 /*MBIST Status Low Register*/
 while(STCU_MBSLSW !=0x07ffffff );
/*      Init system registers for shutdown selftest                         */
static void Pre_ShutDownSelfTest()
/*     1. End the currently running application, including graceful termination of
 peripheralsas required by the application */
/* 2. Configure FlexRay and CAN clock sources and divider for self-test:*/
 MC_CGM.AC1_DC0.B.DE = 1;
 MC_CGM.AC1_DC0.B.DIV = 1;
 FR_0.MCR.B.CLKSEL=1;
 CAN_0.CTRL1.B.CLKSRC=1;
 CAN_1.CTRL1.B.CLKSRC=1;
 CAN_2.CTRL1.B.CLKSRC=1;
/* 3. Ensure PBRIDGE clock is not over clocked (maximum frequency is 50MHz) when SYS_CLK is switched to 200MHz.  */
   MC_CGM.SC_DC0.B.DIV = 3;
/* 4. Configure DRUN to turn off PLL1 (to save power), turn off PLL0 so PLL0 can bere-configured for the required 200MHz self-test clock frequency, turn on the XOSC
    as it is needed to provide the PLL0 reference clock during self-test, and select IRCOSC to source SYS_CLK: */
   MC_ME.DRUN_MC.B.SYSCLK=0;/*Select IRCOSC as the SYS_CLK clock source*/
      MC_ME.DRUN_MC.B.XOSCON=1;/*Enable XOSC*/
   MC_ME.DRUN_MC.B.PLL0ON=0;/*Disable PLL0:*/
   MC_ME.DRUN_MC.B.PLL1ON=0;/*Disable PLL1*/
 /*Gate off all peripheral clocks because they should not be running: */
   MC_ME.RUN_PC[0].B.DRUN  =0;
   MC_ME.RUN_PC[1].B.DRUN  =0;
   MC_ME.RUN_PC[2].B.DRUN  =0;
   MC_ME.RUN_PC[3].B.DRUN  =0;
   MC_ME.RUN_PC[4].B.DRUN  =0;
   MC_ME.RUN_PC[5].B.DRUN  =0;
   MC_ME.RUN_PC[6].B.DRUN  =0;
   MC_ME.RUN_PC[7].B.DRUN  =0;
   MC_ME.PCTL9.B.RUN_CFG=0;
   MC_ME.PCTL11.B.RUN_CFG=0;
   MC_ME.PCTL12.B.RUN_CFG=0;
   MC_ME.PCTL30.B.RUN_CFG=0;
   MC_ME.PCTL36.B.RUN_CFG=0;
   MC_ME.PCTL38.B.RUN_CFG=0;
   MC_ME.PCTL77.B.RUN_CFG=0;
   MC_ME.PCTL78.B.RUN_CFG=0;
   MC_ME.PCTL79.B.RUN_CFG=0;
   MC_ME.PCTL91.B.RUN_CFG=0;
   MC_ME.PCTL98.B.RUN_CFG=0;
   MC_ME.PCTL99.B.RUN_CFG=0;
   MC_ME.PCTL104.B.RUN_CFG=0;
   MC_ME.PCTL107.B.RUN_CFG=0;
   MC_ME.PCTL124.B.RUN_CFG=0;
   MC_ME.PCTL126.B.RUN_CFG=0;
   MC_ME.PCTL137.B.RUN_CFG=0;
   MC_ME.PCTL141.B.RUN_CFG=0;
   MC_ME.PCTL144.B.RUN_CFG=0;
   MC_ME.PCTL146.B.RUN_CFG=0;
   MC_ME.PCTL204.B.RUN_CFG=0;
   MC_ME.PCTL208.B.RUN_CFG=0;
   MC_ME.PCTL209.B.RUN_CFG=0;
   MC_ME.PCTL214.B.RUN_CFG=0;
   MC_ME.PCTL235.B.RUN_CFG=0;
   MC_ME.PCTL237.B.RUN_CFG=0;
   MC_ME.PCTL239.B.RUN_CFG=0;
   MC_ME.PCTL245.B.RUN_CFG=0;
   MC_ME.PCTL247.B.RUN_CFG=0;
   MC_ME.PCTL251.B.RUN_CFG=0;
   MC_ME.PCTL255.B.RUN_CFG=0;
/* 5. Activate new configuration by performing mode change to DRUN: */
  // MC_ME.MCTL.B.TARGET_MODE = 3;
 MC_ME.MCTL.R = 0x30005AF0;                  /* Mode & Key */
 MC_ME.MCTL.R = 0x3000A50F;                  /* Mode & Key inverted */
 while(MC_ME.GS.B.S_MTRANS == 1);            /* Wait for mode entry to complete */
 while(MC_ME.GS.B.S_CURRENT_MODE != 0x3);    /* Check DRUN mode has been entered */
/* 6. Configure PLL0 for required 200MHz self-test frequency: */
    /* a. Configure PLL0 to provide 100MHz at its PHI output: (values depend on XOSC frequency). */
  //PLLDIG_PLL0DV =
  PLLDIG.PLL0DV.B.RFDPHI1 = 8;
  PLLDIG.PLL0DV.B.RFDPHI = 4;
  PLLDIG.PLL0DV.B.PREDIV = 1;
  PLLDIG.PLL0DV.B.MFD = 25;
 /*Select XOSC as PLL0's reference clock*/
   MC_CGM.AC3_SC.B.SELCTL=1;
/* 7. Configure DRUN mode to turn on PLL0 and select PLL0 PHI to source SYS_CLK: */
   MC_ME.DRUN_MC.B.XOSCON=1;/*Enable XOSC:*/
   MC_ME.DRUN_MC.B.PLL0ON=1;/*Enable PLL0:*/
   MC_ME.DRUN_MC.B.PLL1ON=0;/*Disable PLL1:*/
      MC_ME.DRUN_MC.B.SYSCLK=2;/*Select PLL0 PHI as the SYS_CLK clock source*/
/* 8. Activate new configuration by performing mode change to DRUN: */
     // MC_ME.MCTL.B.TARGET_MODE=3;
/* 9. Select PLL0 PHI to source all auxiliary clocks used during self-test */
   MC_CGM.AC0_SC.B.SELCTL=2;
   MC_CGM.AC5_SC.B.SELCTL=2;
*  @par Description
*  This function init all shutdown selftest registers and start shutdown selftest.
*  @param  NULL
*  @return  NULL
static void ShutDownSelfTest_Init()
    STCU.SKC.R = 0x753F924E;
    STCU.SKC.R = 0x8AC06DB1;
 /*2 :configure all STCU MBn CTRL register:*/
 STCU_MB0_CTRL   =0X91000000;
 STCU_MB1_CTRL   =0x98000000;
 STCU_MB2_CTRL   =0x93000000;
 STCU_MB3_CTRL =0x94000000;
 STCU_MB4_CTRL =0x95000000;
 STCU_MB5_CTRL =0x96000000;
 STCU_MB6_CTRL =0x97000000;
 STCU_MB7_CTRL =0x10000000;
 STCU_MB8_CTRL =0x99000000;
 STCU_MB9_CTRL =0x9a000000;
 STCU_MB10_CTRL =0x9b000000;
 STCU_MB11_CTRL =0x9c000000;
 STCU_MB12_CTRL =0x9d000000;
 STCU_MB13_CTRL =0x9e000000;
 STCU_MB14_CTRL =0x9f000000;
 STCU_MB15_CTRL =0xa0000000;
 STCU_MB16_CTRL =0xa1000000;
 STCU_MB17_CTRL =0xa2000000;
 STCU_MB18_CTRL =0xa3000000;
 STCU_MB19_CTRL =0xa4000000;
 STCU_MB20_CTRL =0xa5000000;
 STCU_MB21_CTRL =0xa6000000;
 STCU_MB22_CTRL =0xa7000000;
 STCU_MB23_CTRL =0xa8000000;
 STCU_MB24_CTRL =0xa9000000;
 STCU_MB25_CTRL =0xaa000000;
 STCU_MB26_CTRL =0x00000000;
 /*3:config stcu_cfg register*/
 STCU_CFG  = 0X12000008;
 /*4:configure all STCU_Lbn_Ctrl register*/
 STCU_LB0_CTRL = 0x83031107;
 STCU_LB1_CTRL = 0X82031107;
 STCU_LB2_CTRL = 0X7F031107;
 STCU_LB3_CTRL = 0X01031107;
 /*5:configure all STCU_LBnMISRELSW /STCU_LBnMISREHSW register*/
 STCU_LB0_PCS = 0x00006590;
 STCU_LB1_PCS = 0x00000708;
 STCU_LB2_PCS = 0x00000B00;
 STCU_LB3_PCS = 0x00000740;
 STCU_LB0_MISRELSW = 0xe19ee01f;
 STCU_LB1_MISRELSW = 0xf1b392f7;
 STCU_LB2_MISRELSW = 0xc0129454;
 STCU_LB3_MISRELSW = 0xe0d719d0;
 STCU_LB0_MISREHSW = 0xAA0EE288;
 STCU_LB1_MISREHSW = 0x18916197;
 STCU_LB2_MISREHSW = 0xDE0D037E;
 STCU_LB3_MISREHSW = 0x694A0066;
 /*6:configure all STCU_WDG register*/
 STCU_WDG = 0x00060000;
 /*7:configure STCU_LBRMSW register*/
 STCU_LBRMSW = 0x0000000f;
 /*8:configure DCL_IPS0 register*/
 DCL_IPS0 = 0x03008214;
 /*configure the STCU_RUNSW register ---- start the shutdown self-test*/
 STCU_RUNSW = 0x00000301;
 //wait  the shutdown self-test finished
  while (STCU.RUNSW.B.RUNSW == 1);
3,006件の閲覧回数
petervlna
For different cuts you need different MISR values.
For 1N15P use following:
STCU_LB0_MISREL
0x8CBF311B
STCU_LB1_MISREL
0xAC435093
STCU_LB2_MISREL
0x37732C00
STCU_LB3_MISREL
0xB4B9D509
STCU_LB0_MISREH
0xCD9077D8
STCU_LB1_MISREH
0x01599F6C
STCU_LB2_MISREH
0x23EA1647
STCU_LB3_MISREH
0xF3A1B551
We have created ticket for reference manual update.
Peter
3 返答(返信)
3,007件の閲覧回数
petervlna
STCU_LB0_MISREL
0x8CBF311B
STCU_LB1_MISREL
0xAC435093
STCU_LB2_MISREL
0x37732C00
STCU_LB3_MISREL
0xB4B9D509
STCU_LB0_MISREH
0xCD9077D8
STCU_LB1_MISREH
0x01599F6C
STCU_LB2_MISREH
0x23EA1647
STCU_LB3_MISREH
0xF3A1B551
Peter
3,006件の閲覧回数
xiaobozheng
where we can find the ref manual?
3,006件の閲覧回数
petervlna
You can find on our web page all available documentation.
http://cache.nxp.com/files/32bit/doc/ref_manual/MPC5744PRM.pdf?fsrch=1&sr=4&pageNum=1
Peter
