SPC5607B SWT Problem
3,348件の閲覧回数
yankuang1
Hi ,
I set the timeout reset time of SWT to 10s, and when I enable the interruption, SWT can normally reset after 10s timeout and F_CHECKSTOP set.
But if the interrupt is not turned on, 20s is needed before resetting. The resetting register is F_SOFT. Please help to check why this situation occurs.
3,253件の閲覧回数
petervlna
reference manual:
If the interrupt is not enabled the device will be reset after 10s
If it is enabled and not SWT in not updated in interrupt it will reset on second timeout. 20s
regards,
Peter
