SPC5606 Spread function
2,381件の閲覧回数
hansonhe
Customers are now doing EMC experiments in the laboratory. When testing at 320MHZ and 448MHZ frequency points, there will be a situation of exceeding the standard. At present, the main frequency of SPC5606 runs at 64MHZ.
Whether SPC5606S has Spread Spectrum function or not, see the data manual should be Freq Modulation module, that is Modulation Register. How to configure the specific guidance, whether there is a reference code, thank you.
2,297件の閲覧回数
petervlna
I have posted example with calculations here:
https://community.nxp.com/docs/DOC-332383
The code is compatible with SPC5606S,
regards,
Peter
