PWMMAC eTPU API inconsistent behavior
ukirde_pramod
We are using PWMMAC etpu library functions. We have observed the unclear behavior of this API.
Our assumptions based on application note (AN2969) is -
When the duty cycle is configured in such a way that the On time of pulse is lower than half the dead time, the PWM turns off.
But our observations are different,
e.g.
When we try to give switching frequency of 20 Khz, dead time of 3.2 microseconds,  Duty cycle = 10% (5 microsecond),
we expect the pulse width of 1.8 microsecond, but we get 2.79 Microseconds.
we exercise this for different duty cycles but we didn't observe the consistency.
Can you please explain this behavior?
davidtosenovjan
Hi, if it is still an issue, could you provide more details about your configuration? Thanks
