MPC5777c Programming UTEST Problem
1,659 次查看
marv_marsian
I have used the instructions listed in Solved: MPC5777C update DCF record - NXP Community to program STCU2 module. I made a mistake and wrote a wrong value in my xxx.srec file, thus to the 0x00400310 address. I tried to overwrite it but the PROGPPCNEXUS program throws `Error during programming` error(nothing else).
I already read that UTEST flash area cannot be deleted, but is it also non-re-writable? Is there a way to over-write this address?
Thanks to anyone who reads.
Best wishes.
1,645 次查看
lukaszadrapa
Hi Ekrem,
I'm afraid there's no solution for this. Erase is not allowed and cumulative programming is also not allowed - only one program operation is allowed per 64-bit ECC segment.
If you made a mistake in UTEST, the only option is usually to replace the chip.
Lukas
