MPC5777C IPC shared memory
1,525 次查看
San_96
What are the chapters in MPC5777C describe about data sharing between two Core processors ?
1,501 次查看
lukaszadrapa
there's no such chapter. Both cores have an access to whole memory map, so you can use any part of RAM memory as shared memory. I can only recommend to configure this shared memory as cache inhibited - this can be done using MMU. And to ensure data coherency, you can use semaphores (SEMA4 module).
Lukas
1,502 次查看
lukaszadrapa
Lukas
