MPC5748G example app uart (LINFLEXD_UART_DRV_ReceiveDataBlocking)
2,863件の閲覧回数
kalai
HI,
   i try to run uart  example UART is not working . uart tranmission is working but receiver is not working (LINFLEXD_UART_DRV_ReceiveDataBlocking)
 i need some details
thanks
kalai
2,824件の閲覧回数
PetrS
I tested both examples and it works, I can receive bytes sent from PC.
Just for uart_pal_mpc5748g example, PC terminal must be set to send endline upon enter as mentioned in example doxygen file.
For linflexd_uart_echo_mpc5748g example I just increase timeout value in ReceiveData Blocking function so I was able to write Hello from terminal in time.
BR, Petr
3 返答(返信)
2,845件の閲覧回数
PetrS
which example and board do you use?
Did you refer to e.g. SDK based example "inflexd_uart_echo_mpc5748g" within S32DS and follow description given in Doxygen inflexd_uart_echo_mpc5748g.dox file?
BR, Petr
2,843件の閲覧回数
kalai
HI petrs,
   i am using DEVKIT-mpc5748G board.i run example code( linflexd_uart_echo_mpc5748g,uart_pal_mpc5748g) only ,receiver is not working
thanks
kalai
2,825件の閲覧回数
PetrS
BR, Petr
