MPC5748G: How to write data to your desired address space in EEPROM
1,494 次查看
priya_p
I am using MPC5748G dev kit and i am executing it on S32DS. I have a query regarding EEPROM. how to select our desired address space in EEPROM and what is the relation between id and EEPROM?
标记 (3)
1,485 次查看
lukaszadrapa
take a look at this SW example:
c:\NXP\S32DS_Power_v2.1\S32DS\software\S32_SDK_S32PA_RTM_3.0.3\examples\MPC5748G\demo_apps\eeprom_emulation\
When you open EEE component, you will see how to define the blocks:
Also read section "17.27 EEPROM Emulation (EEE)" in the user manual:
c:\NXP\S32DS_Power_v2.1\S32DS\software\S32_SDK_S32PA_RTM_3.0.3\doc\S32SDK_MPC5748G_UserManual.pdf
Regarding ID - each record has own ID. This ID is used when you write or read your data. The best way is to step the example code to understand how it works.
Lukas
1,486 次查看
lukaszadrapa
Lukas
