MPC5746C Flash array integrity test
Rajesh_Y
I am working of MPC5746C controller.
I have a safety requirement to run Flash array integrity test.
I am able to run the test but how can i calculate the signature of the code flash blocks so that I can compare with the output of the array integrity test.
Thanks in advance.
Rajesh
Rajesh_Y
Hello Lukas,
Thanks for the help.
It has solved my problem
Rajesh
lukaszadrapa
Hi Rajesh,
there's offline MISR calculator included in SSD flash drivers:
https://www.nxp.com/webapp/Download?colCode=C55_NVM_SSD
Install the package and then see:
c:\Program Files (x86)\Freescale\Standard Software Driver v1.1.0\MPC57xx\Tool\MISR_gen\
There's readme file which explains how to use the tool.
Lukas
