MPC5744P Instruction Set
2,634件の閲覧回数
qm1013
hello, Where do I find the Instruction Set on MPCXXX of Power PC ™ instruction set ?
I have found some reference manual, but the instruction set is not completed.
Could you help find some completed reference manual of instruction set ?
Thank you very much !
タグ(3)
2 返答(返信)
2,462件の閲覧回数
lukaszadrapa
there are these two documents:
https://www.nxp.com/docs/en/reference-manual/VLEPEM.pdf
https://www.nxp.com/files-static/32bit/doc/ref_manual/EREFRM.pdf
MPC5744P has VLE instruction set only, so use the first document.
Lukas
2,462件の閲覧回数
qm1013
