MPC5674F using CAN Rx with DMA
EmbUser
I am using MPC5674F controller trying to explore the feature if its possible to use CAN Rx using DMA to improve the performance . can you guide me to a sample code for the above feature.
else what are the other possible options.
thanks,
Nagesh
PetrS
as far as I know, there is no example directly for MPC5674F, but you can refer e.g. to below one
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/Example-MPC5748G-FlexCAN-DMA-ISR/ta-p/1113931
BR, Petr
