MPC5645S Blinky code please
2,798 次查看
peteradamcik
Hi Guys, does anyone have any Assembler or C code to blink a LED on an output port for the MPC5645S?
Please let me know.
Thanks guys
Pete
2,766 次查看
petervlna
here is LED blinking code
For LED conf:
  /*  Toggling Red LED D6 on EVB to observe MCU reset event */
  SIU.GPDO[121].R = 0;             /* MPC56x4xS EVB LED: data output: LED on */
  SIU.PCR[121].R = 0x0200;         /* MPC56x4xS/S EVB LED: enable PK[0] as output */
  /*  Toggling LED D7 on EVB to observe MCU wakeup event */
  SIU.GPDO[70].R = 0;             /* MPC56x4xS EVB LED: data output: LED on */
  SIU.PCR[70].R = 0x0200;         /* MPC56x4xS/S EVB LED: enable PF[0] as output */
Peter
2,767 次查看
petervlna
For LED conf:
Peter
2,784 次查看
petervlna
I have some codes for HVAC or OPEN_VG but those are complex sample codes.
I have asked application team if there is something available. As I do not have the development board here I cant test the code.
However I can write it in case apps dont have one , but not test it here.
Peter
2,782 次查看
peteradamcik
Hi Peter, yes can you please write some code in assembler or C, that would be very much appreciated.
Just need to set the a port to output and blink a LED via a delay.
Would it be possible for you to write it in Assembler? I'm not to good with C.
Thanks Pete
Peter
