MPC5606b Flash sample code
明伟张
Hi everyone
I want have a sample code about the MPC5606b Flash write,read,erase;
thanks a lot;
davidtosenovjan
I suppose you mean runtime programming. It is easiest to use MPC56xx C90LC Flash Standard Software Driver that is available on our website:
http://www.nxp.com/files/soft_dev_tools/software/device_drivers/MPC56XX_C90LC_JDP_SSD_100_DEVD.exe
Example code you will find in its installation directory.
Also I could point out following example showing simple programming without using of SSD drivers. Even though it has been written for other devices, the principle is similar:
Example MPC5643L Flash_program_simple CW210
Example MPC5675K Data_flash_program_simple CW210
