Example MPC5675K Data_flash_program_simple CW210
* Detailed Description:
* Example show simple flash programming routine. During runtime it changes
* content of field of constants 'test' (located in internal data flash).
* Also it shows how to relocate data into FLASH (used linker command file
* is MPC5675K_my_sections.lcf and MPC5675K_DEBUG_my_sections.lcf).
* Note: For complex tasks use SSD driver (Freescale site for particular device,
* Software&Tools/Run-Time Software/Middleware-Device Drivers
* Test HW:        MPC5675KEVB
* MCU:            PPC5675KFMMSJ in Lock-Step mode
* Fsys:           180/150 MHz CORE_CLK
* Debugger:       Lauterbach Trace32
*                 PeMicro USB-ML-PPCNEXUS
* Target:         RAM, internal_FLASH
* Terminal:       19200-8-no parity-1 stop bit-no flow control on eSCI_A
* EVB connection: default
%3CLINGO-SUB%20id%3D%22lingo-sub-1118374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5675K%20Data_flash_program_simple%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Example%20show%20simple%20flash%20programming%20routine.%20During%20runtime%20it%20changes%20%3C%2FP%3E%3CP%3E*%20content%20of%20field%20of%20constants%20'test'%20(located%20in%20internal%20data%20flash).%20%3C%2FP%3E%3CP%3E*%20Also%20it%20shows%20how%20to%20relocate%20data%20into%20FLASH%20(used%20linker%20command%20file%3C%2FP%3E%3CP%3E*%20is%20MPC5675K_my_sections.lcf%20and%20MPC5675K_DEBUG_my_sections.lcf).%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20Note%3A%20For%20complex%20tasks%20use%20SSD%20driver%20(Freescale%20site%20for%20particular%20device%2C%20%3C%2FP%3E%3CP%3E*%20Software%26amp%3BTools%2FRun-Time%20Software%2FMiddleware-Device%20Drivers%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5675KEVB%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5675KFMMSJ%20in%20Lock-Step%20mode%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20180%2F150%20MHz%20CORE_CLK%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3C%2FP%3E%3CP%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%20default%20%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1118374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Example%20show%20simple%20flash%20programming%20routine.%20During%20runtime%20it%20changes%20%3C%2FP%3E%3CP%3E*%20content%20of%20field%20of%20constants%20'test'%20(located%20in%20internal%20data%20flash).%20%3C%2FP%3E%3CP%3E*%20Also%20it%20shows%20how%20to%20relocate%20data%20into%20FLASH%20(used%20linker%20command%20file%3C%2FP%3E%3CP%3E*%20is%20MPC5675K_my_sections.lcf%20and%20MPC5675K_DEBUG_my_sections.lcf).%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20Note%3A%20For%20complex%20tasks%20use%20SSD%20driver%20(Freescale%20site%20for%20particular%20device%2C%20%3C%2FP%3E%3CP%3E*%20Software%26amp%3BTools%2FRun-Time%20Software%2FMiddleware-Device%20Drivers%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5675KEVB%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5675KFMMSJ%20in%20Lock-Step%20mode%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20180%2F150%20MHz%20CORE_CLK%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3C%2FP%3E%3CP%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%20default%20%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1118374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
100% helpful (1/1)
Version history
Last update:
‎12-17-2015 06:27 AM
Updated by:
