MPC5604E Video Frame Rate
1,993 次查看
suhass
As mentioned in the MPC5604E's reference mannual, it can take 1280x800 @ 30fps, can it process higher frame rate data at lower resolution, for eg. 640x480 @ 60fps or 564x756 @ 50fps.
标记 (1)
1,915 次查看
martin_kovar
yes, you can set lower resolution with higher frame rate. The only limitation is 100MHz clock at PDI camera interface.
Regards.
Martin
1,915 次查看
suhass
Hi NXP,
Please reply to this query ASAP.
