How to access macro variable to an asm function in mpc5746
1,222件の閲覧回数
renjithr
How to access the following macro to my inline-asm function, and to store 32 bit value to that location
#define STATUS_VAR (*(volatile uint32_t*)0x40008025u)
asm void testFunc(void)
1,124件の閲覧回数
lukaszadrapa
you can't do that. It is not possible to put C expression to asm code. You can do that only if it is pure number like:
#define STATUS_VAR 0x40008025U
Lukas
