Inconsistent CAN reception Issue
4,121件の閲覧回数
Anilpatil_SasvaAuto
Subject: Inconsistent CAN Message Reception Issue
Hello Team,
I am encountering an issue with receiving CAN messages consistently. I have configured 4 message buffers (MBs) to receive 4 Rx messages.
Issue:
Observation 1: When I send the first message (0x301) from the IG block in the CANOE tool, the MPC5748G micro can receive the message, and the respective ISR hits. However, if I send the same message again, the ISR does not hit at any time.
Observation 2: Following observation 1, if I send the second message (0x302), the MPC5748G micro can receive the message, and the respective ISR hits. If I send the first message again, the ISR hits, but subsequent attempts to send the same message do not trigger the ISR.
Observation 3: If the same message is sent successively, none of the ISRs will be triggered repeatedly. However, sending four different messages one by one will trigger the respective ISRs.
Your help with this issue would be greatly appreciated. Please provide the solution on urgent basis.
Thank you.
Please review the following functions:
1.CAN Initialization function:
void Can_InitCAN0 (void)
uint8_t index;
CAN_0.MCR.B.MDIS = 1; /* Disable module before selecting clock source*/
CAN_0.CTRL1.B.CLKsrc=0; /* Clock Source = oscillator clock (40 MHz) */
CAN_0.MCR.B.MDIS = 0; /* Enable module for config. (Sets FRZ, HALT)*/
while (!CAN_0.MCR.B.FRZACK) {}/* Wait for freeze acknowledge to set */
/* Good practice: wait for FRZACK on freeze mode entry/exit */
CAN_0.CTRL1.R = 0x04DB0086; /* CAN bus: 40 MHz clksrc, 500 kbps with 16 tq */ // 0x27590000
/* PRESDIV+1 = Fclksrc/Ftq = 40 MHz/8MHz = 5 */
/* so PRESDIV = 4 */
/* PSEG2 = Phase_Seg2 - 1 = 4 - 1 = 3 */
/* PSEG1 = PSEG2 = 3 */
/* PROPSEG= Prop_Seg - 1 = 7 - 1 = 6 */
/* RJW = Resync Jump Width - 1 = 4 = 1 */
/* SMP = 1: use 3 bits per CAN sample */
/* CLKsrc=0 (unchanged): Fcanclk= Fxtal= 40 MHz*/
CAN_0.MCR.R |= CAN_MCR_FRZ | CAN_MCR_HALT; /* enabled to enter Freeze mode */
while (0 == CAN_0.MCR.B.FRZACK){};
while (0 == CAN_0.MCR.B.NOTRDY){}; /* double check that we are actually in freeze mode */
CAN_0.MCR.B.IRMQ = 1; /* Individual Rx Masking And Queue Enable */
#ifdef CAN_0_LOOP_BACK_ENABLED
CAN_0.MCR.B.SRXDIS = 0; /* Self Reception Enable */
#else
CAN_0.MCR.B.SRXDIS = 1; /* Self Reception Disable */
#endif
CAN_0.MCR.B.RFEN = 0; /* RX FIFO Disabled */
CAN_0.MCR.B.AEN = 1; /* Abort Enabled */
CAN_0.MCR.B.FDEN = 0; /* CAN-FD Enabled */
CAN_0.MCR.B.IDAM = 0; /* ID Acceptance Mode is one full ID */
CAN_0.MCR.B.MAXMB = 0x3F; /* 64 MBs */
CAN_0.CTRL1.B.SMP = 1; /* SMP = 1: use 3 bits per CAN sample */
CAN_0.CTRL1.B.LPB = 1; /* Loopback Enabled */
#else
CAN_0.CTRL1.B.LPB = 0; /* Loopback Disabled */
#endif
for (index=0; index<96; index++)
CAN_0.MB[index].CS.R = 0; /* Inactivate all 96 message buffers */
/****Disable CAN FD****/
#if 0
CAN_0.FDCTRL.B.FDRATE = 1; /* Flexible Data Rate Enabled */
CAN_0.FDCTRL.B.MBDSR0 = 0; /* MB data size for R0 is 8 Bytes */
CAN_0.FDCTRL.B.MBDSR1 = 3; /* MB data size for R1 is 64 Bytes */
CAN_0.FDCTRL.B.MBDSR2 = 3; /* MB data size for R2 is 64 Bytes */
CAN_0.CBT.R = 0x80242844; /* Bit timing parameters */
CAN_0.FDCBT.R = 0x001614C6; /* Bit timing parameters */
#endif
CAN_0.RXIMR[index].R = 0x1FFFFFFF; /* RX Individual Mask is set to check all bits with MB ID */
CAN_0.RXIMR[45].R = 0; /* MB 45 used for TX */
/* enable interrupt for MB45 - Transmit complete Interrupt */
CAN_0.IMASK2.R |= 1U << 13U;
Can_InitCAN0RxMsgBuffers ();
CAN_0.RXMGMASK.R = 0x1FFFFFFF;
INTC.PSR[568].B.PRC_SELN = 0x8;
INTC.PSR[568].B.PRIN = 12;
INTC.PSR[569].B.PRC_SELN = 0x8;
INTC.PSR[569].B.PRIN = 12;
INTC.PSR[570].B.PRC_SELN = 0x8;
INTC.PSR[570].B.PRIN = 12;
INTC.PSR[571].B.PRC_SELN = 0x8;
INTC.PSR[571].B.PRIN = 12;
INTC.PSR[572].B.PRC_SELN = 0x8;
INTC.PSR[572].B.PRIN = 12;
INTC.PSR[573].B.PRC_SELN = 0x8;
INTC.PSR[573].B.PRIN = 12;
Can0PortInit ();
/*CAN_0.CTRL2.R |= 0x00001000u; // ISOCANFD Enabled*/
CAN_0.IFLAG1.R = 0xFFFFFFFFU;
CAN_0.IFLAG2.R = 0xFFFFFFFFU;
/* enable the FlexCAN module, reset and freeze */
CAN_0.MCR.R &= ~(CAN_MCR_FRZ | CAN_MCR_HALT);
while (CAN_0.MCR.B.FRZACK & CAN_0.MCR.B.NOTRDY) {} /* Wait to clear */
2.CAN ISR for 4 MBs are as below:
void Can_MsgBuf0003ISR (void)
uint8 Channel;
uint8 ReturnValue = 0U;
uint32 RegValue;
Channel = 0U;
if (0U != (CAN_0.IFLAG1.R & (1U << Can_RxMsgBufConfig[Channel].MB)))
ReturnValue |= Can_RxMsg ( Channel, Can_RxMsgBufConfig[Channel].MsgPtr);
Channel = 1U;
Channel = 2U;
Channel = 3U;
3.Message buffers initialization function:
void Can_InitCAN0RxMsgBuffers (void)
uint8 MsgIndex;
uint32 StandardID;
for (MsgIndex=0; MsgIndex < NUM_OF_RX_MSGS; MsgIndex++)
StandardID = Can_RxMsgBufConfig[MsgIndex].StdID;
*((uint32 *)(CAN0_BASE_REG_ADDR + Can_RxMsgBufConfig[MsgIndex].MBAddrOffset)) = MB_CS_SET_EDL | MB_CS_SET_BRS | MB_CS_CODE_INACTIVE | MB_CS_STD_IDE;
*((uint32 *)(CAN0_BASE_REG_ADDR + Can_RxMsgBufConfig[MsgIndex].MBAddrOffset + 4U)) = MB_STD_ID & (StandardID << 18);
*((uint32 *)(CAN0_BASE_REG_ADDR + Can_RxMsgBufConfig[MsgIndex].MBAddrOffset)) |= MB_CS_CODE_EMPTY;
if (Can_RxMsgBufConfig[MsgIndex].MB < 32U)
CAN_0.IMASK1.R |= 1 << Can_RxMsgBufConfig[MsgIndex].MB;
else
CAN_0.IMASK2.R |= 1 << (Can_RxMsgBufConfig[MsgIndex].MB - 32U);
4.Receive_Msg() function:
uint8 Can_RxMsg (uint8 Channel, Can_MsgType * Msg)
uint32 IFlag;
uint8 *P8CAN0RxMBData;
uint8 Index;
if (Channel < NUM_OF_RX_MSGS)
if (Can_RxMsgBufConfig[Channel].MB < 32U)
IFlag = CAN_0.IFLAG1.R & (1U << Can_RxMsgBufConfig[Channel].MB);
else
IFlag = CAN_0.IFLAG2.R & (1U << (Can_RxMsgBufConfig[Channel].MB - 32U));
if (0U != IFlag)
Msg->StdID = ((*((uint32 *)(CAN0_BASE_REG_ADDR + Can_RxMsgBufConfig[Channel].MBAddrOffset + 4U))) & MB_STD_ID) >> 18;
Msg->DLC = ((*((uint32 *)(CAN0_BASE_REG_ADDR + Can_RxMsgBufConfig[Channel].MBAddrOffset))) & MB_CS_DLC) >> 16;
Msg->NoOfBytes = Can_CalcNoOfBytes (Msg->DLC);
P8CAN0RxMBData = (uint8 *) (CAN0_BASE_REG_ADDR + Can_RxMsgBufConfig[Channel].MBAddrOffset + 8U);
for (Index=0; Index < Msg->NoOfBytes; Index++)
Msg->Payload[Index] = *(P8CAN0RxMBData + Index); /* Load data to be transmitted */
CAN_0.IFLAG1.R = (1U << Can_RxMsgBufConfig[Channel].MB);
else
CAN_0.IFLAG2.R = (1U << (Can_RxMsgBufConfig[Channel].MB - 32U));
LED_DS7 = ~LED_DS7;
Msg->MsgRcvd++;
ReturnValue = 1U;
return (ReturnValue);
5.Unmask Interrupt function:
void Can_UnMaskInterrupt (uint8 Channel, uint32 RegValue)
uint8 IntrID = Can_RxMsgBufConfig[Channel].IntrID;
switch (IntrID)
case 0U : CAN_0.IMASK1.R = RegValue;
break;
case 1U : CAN_0.IMASK1.R = RegValue;
break;
case 2U : CAN_0.IMASK1.R = RegValue;
break;
case 3U : CAN_0.IMASK1.R = RegValue;
break;
case 4U : CAN_0.IMASK1.R = RegValue;
break;
case 5U : CAN_0.IMASK2.R = RegValue;
break;
default : break;
6.Mask Interrupt function:
uint32 Can_MaskInterrupt (uint8 Channel)
uint32 RegValue;
switch (IntrID)
case 0U : RegValue = CAN_0.IMASK1.R;
CAN_0.IMASK1.R &= 0xFFFFFFF0U; // MB 0-3
break;
case 1U : RegValue = CAN_0.IMASK1.R;
CAN_0.IMASK1.R &= 0xFFFFFF0FU; // MB 4-7
break;
case 2U : RegValue = CAN_0.IMASK1.R;
CAN_0.IMASK1.R &= 0xFFFFF0FFU; // MB 8-11
break;
case 3U : RegValue = CAN_0.IMASK1.R;
CAN_0.IMASK1.R &= 0xFFFF0FFFU; // MB 12-15
break;
case 4U : RegValue = CAN_0.IMASK1.R;
CAN_0.IMASK1.R &= 0x0000FFFFU; // MB 16 - 31
break;
case 5U : RegValue = CAN_0.IMASK2.R;
CAN_0.IMASK2.R &= 0x00000000U; // MB 32+ ... including MB 45 used for TX
break;
default : break;
return RegValue;
4,105件の閲覧回数
PetrS
a behavior is due to way you unlock MB. The MB is locked when reading its Control&Status word, it is unlocked when user read free running timer register or read another MB's CS word. When MB is locked it is not free to receive. Read chapter 43.5.7.3 Mailbox lock mechanism for more info.
As you do not unlock MB globally, using CAN_TIMER read, then the MB will get new message once another one is serviced, that is your observation 3.
So add reading CAN_TIMER after MB is serviced in your Can_RxMsg function.
And remove CAN_0.IFLAG1.R = 0xFFFFFFFFU;CAN_0.IFLAG2.R = 0xFFFFFFFFU; lines at the end as it can also clear other asserted flags. Clear just flag for serviced MB.
BR, Petr
5 返答(返信)
4,106件の閲覧回数
PetrS
BR, Petr
4,099件の閲覧回数
Anilpatil_SasvaAuto
how to read the CAN_TIMER after MB
4,102件の閲覧回数
Anilpatil_SasvaAuto
Hello Petr,
Thanks for your reply.
could you please provide the example code to resolve my issue.
Requirement: Each ISR shall hit on successful reception of the respective messages.
please its very urgent
4,098件の閲覧回数
PetrS
try below function
uint32 IFlag, dummy;
uint8 Index;
else
if (0U != IFlag)
else
dummy = CAN_0.TIMER.R;  // unlock MB globally
LED_DS7 = ~LED_DS7;
Msg->MsgRcvd++;
ReturnValue = 1U;
//CAN_0.IFLAG1.R = 0xFFFFFFFFU;
//CAN_0.IFLAG2.R = 0xFFFFFFFFU;
BR, Petr
4,092件の閲覧回数
Anilpatil_SasvaAuto
Thanks for your support.
Somewhat working. I will let you know the behavior after the complete testing.
%3CLINGO-SUB%20id%3D%22lingo-sub-1969942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%AE%E3%81%AA%E3%81%84CAN%E5%8F%97%E4%BF%A1%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1969942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%B6%E5%90%8D%3A%20%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%AE%E3%81%AA%E3%81%84%20CAN%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E5%8F%97%E4%BF%A1%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%81%E3%83%BC%E3%83%A0%E3%80%81%3C%2FP%3E%3CP%3ECAN%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E4%B8%80%E8%B2%AB%E3%81%97%E3%81%A6%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%824%E3%81%A4%E3%81%AERx%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%814%E3%81%A4%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1(MB)%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%99%BA%E8%A1%8C%EF%BC%9A%3CBR%20%2F%3E%E8%A6%B3%E5%AF%9F%201%3A%20CANOE%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%20IG%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8B%E3%82%89%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%20(0x301)%20%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81MPC5748G%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%81%8C%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%20ISR%20%E3%81%8C%E3%83%92%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%86%8D%E5%BA%A6%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%82%82%E3%80%81ISR%E3%81%AF%E3%81%84%E3%81%A4%E3%81%A7%E3%82%82%E3%83%92%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E8%A6%B3%E5%AF%9F2%3A%E8%A6%B3%E5%AF%9F1%E3%81%AB%E7%B6%9A%E3%81%84%E3%81%A6%E3%80%812%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8(0x302)%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81MPC5748G%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%81%8C%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AEISR%E3%81%8C%E3%83%92%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%86%8D%E5%BA%A6%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81ISR%20%E3%81%AF%E3%83%92%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E5%90%8C%E3%81%98%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%82%82%20ISR%20%E3%81%AF%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E8%A6%B3%E5%AF%9F%203%3A%20%E5%90%8C%E3%81%98%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%A6%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81ISR%20%E3%81%AF%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%814%20%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%201%20%E3%81%A4%E3%81%9A%E3%81%A4%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%20ISR%20%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8A%A9%E3%81%91%E3%81%AF%E5%A4%A7%E6%AD%93%E8%BF%8E%E3%81%A7%E3%81%99%E3%80%82%E7%B7%8A%E6%80%A5%E3%81%AB%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E1.CAN%E5%88%9D%E6%9C%9F%E5%8C%96%E6%A9%9F%E8%83%BD%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Evoid%20Can_InitCAN0%20(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Euint8_t%20index%3B%3C%2FP%3E%3CP%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82B.MDIS%20%3D%201%3B%2F*%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99*%2F%3CBR%20%2F%3ECAN_0.CTRL1.B.CLKsrc%3D0%3B%2F*%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%20%3D%20%E7%99%BA%E6%8C%AF%E5%99%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20(40MHz)%20*%2F%3CBR%20%2F%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82B.MDIS%20%3D%200%3B%2F*%20config%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82(FRZ%E3%80%81HALT%E3%82%BB%E3%83%83%E3%83%88)*%2F%3C%2FP%3E%3CP%3E%E4%B8%80%E6%96%B9%20(!CAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82B.FRZACK)%20%7B%7D%2F*%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E7%A2%BA%E8%AA%8D%E3%82%92%E5%BE%85%E3%81%A4%20*%2F%3CBR%20%2F%3E%2F*%20%E8%89%AF%E3%81%84%E6%96%B9%E6%B3%95%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E9%96%8B%E5%A7%8B%2F%E7%B5%82%E4%BA%86%E6%99%82%E3%81%AB%20FRZACK%20%E3%82%92%E5%BE%85%E3%81%A4%20*%2F%3C%2FP%3E%3CP%3ECAN_0.Ctrl1%20%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82R%20%3D%200x04DB0086%3B%2F*%20CAN%20%E3%83%90%E3%82%B9%3A%2040%20MHz%20clksrc%2C%20500%20kbps%20with%2016%20tq%20*%2F%20%2F%2F%200x27590000%3CBR%20%2F%3E%2F*%20PRESDIV%2B1%20%3D%20fclksrc%2Fftq%20%3D%2040%20MHz%2F8MHz%20%3D%205%20*%2F%3CBR%20%2F%3E%2F*%20%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81PRESDIV%20%3D%204%20*%2F%3CBR%20%2F%3E%2F*%20PSEG2%20%3D%20Phase_Seg2%20-%201%20%3D%204%20-%201%20%3D%203%20*%2F%3CBR%20%2F%3E%2F*%20PSEG1%20%3D%20PSEG2%20%3D%203%20*%2F%3CBR%20%2F%3E%2F*%20PROPSEG%3D%20Prop_Seg%20-%201%20%3D%207%20-%201%20%3D%206%20*%2F%3CBR%20%2F%3E%2F*%20RJW%20%3D%20%E5%86%8D%E5%90%8C%E6%9C%9F%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E5%B9%85%20-%201%20%3D%204%20%3D%201%20*%2F%3CBR%20%2F%3E%2F*%20SMP%20%3D%201%3A%20CAN%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%94%E3%81%A8%E3%81%AB3%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%20*%2F%3CBR%20%2F%3E%2F*%20CLKsrc%3D0%20(%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97)%3A%20Fcanclk%3D%20Fxtal%3D%2040%20MHz*%2F%3C%2FP%3E%3CP%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82R%20%7C%3D%20CAN_MCR_FRZ%20%7CCAN_MCR_HALT%3B%2F*%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20*%2F%3C%2FP%3E%3CP%3E%E4%B8%80%E6%96%B9%20(0%20%3D%3D%20CAN_0.MCR.B.FRZACK)%7B%7D%3B%3CBR%20%2F%3E%E4%B8%80%E6%96%B9%20(0%20%3D%3D%20CAN_0.MCR.B.NOTRDY)%7B%7D%3B%2F*%20%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20*%2F%3C%2FP%3E%3CP%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82B.IRMQ%20%3D%201%3B%2F*%20%E5%80%8B%E3%80%85%E3%81%AE%20Rx%20%E3%83%9E%E3%82%B9%E3%82%AD%E3%83%B3%E3%82%B0%E3%81%A8%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%20*%2F%3CBR%20%2F%3E%23ifdef%20CAN_0_LOOP_BACK_ENABLED%3CBR%20%2F%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82B.SRXDIS%20%3D%200%3B%2F*%20%E3%82%BB%E3%83%AB%E3%83%95%E3%83%AC%E3%82%BB%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E6%9C%89%E5%8A%B9%20*%2F%3CBR%20%2F%3E%23else%3CBR%20%2F%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82B.SRXDIS%20%3D%201%3B%2F*%20%E8%87%AA%E5%B7%B1%E5%8F%97%E4%BF%A1%E7%84%A1%E5%8A%B9%20*%2F%3CBR%20%2F%3E%23endif%3CBR%20%2F%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82B.RFEN%20%3D%200%3B%2F*%20RX%20FIFO%20%E7%84%A1%E5%8A%B9%20*%2F%3CBR%20%2F%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82B.AEN%20%3D%201%3B%2F*%20%E4%B8%AD%E6%AD%A2%E3%81%8C%E6%9C%89%E5%8A%B9%20*%2F%3CBR%20%2F%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82B.FDEN%20%3D%200%3B%2F*%20CAN-FD%20%E5%AF%BE%E5%BF%9C%20*%2F%3CBR%20%2F%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82B.IDAM%20%3D%200%3B%2F*%20ID%20%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%201%20%E3%81%A4%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%20ID%20%E3%81%A7%E3%81%99%20*%2F%3CBR%20%2F%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82B.MAXMB%20%3D%200x3F%3B%2F*%2064%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%20*%2F%3C%2FP%3E%3CP%3ECAN_0.Ctrl1%20%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82B.SMP%20%3D%201%3B%2F*%20SMP%20%3D%201%3A%20CAN%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%94%E3%81%A8%E3%81%AB3%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%20*%2F%3CBR%20%2F%3E%23ifdef%20CAN_0_LOOP_BACK_ENABLED%3CBR%20%2F%3ECAN_0.Ctrl1%20%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82B.LPB%20%3D%201%3B%2F*%20%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E6%9C%89%E5%8A%B9%20*%2F%3CBR%20%2F%3E%23else%3CBR%20%2F%3ECAN_0.Ctrl1%20%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82B.LPB%20%3D%200%3B%2F*%20%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E7%84%A1%E5%8A%B9%20*%2F%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3Efor%20(%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D0%3B%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%26lt%3B96%3B%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%2B%2B)%3CBR%20%2F%3E%7B%3CBR%20%2F%3ECAN_0.MB%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.CS.R%20%3D%200%3B%2F*%2096%20%E5%80%8B%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E9%9D%9E%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%2F****CAN%20FD%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B****%2F%3CBR%20%2F%3E%23if%200%3CBR%20%2F%3ECAN_0.FDCTRL%E3%81%A7%E3%81%99%E3%80%82B.FDRATE%20%3D%201%3B%2F*%20%E3%83%95%E3%83%AC%E3%82%AD%E3%82%B7%E3%83%96%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%88%E5%AF%BE%E5%BF%9C%20*%2F%3CBR%20%2F%3ECAN_0.FDCTRL%E3%81%A7%E3%81%99%E3%80%82B.MBDSR0%20%3D%200%3B%2F*%20R0%20%E3%81%AE%20MB%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%208%20%E3%83%90%E3%82%A4%E3%83%88%20*%2F%3CBR%20%2F%3ECAN_0.FDCTRL%E3%81%A7%E3%81%99%E3%80%82B.MBDSR1%20%3D%203%3B%2F*%20R1%20%E3%81%AE%20MB%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%2064%20%E3%83%90%E3%82%A4%E3%83%88%20*%2F%3CBR%20%2F%3ECAN_0.FDCTRL%E3%81%A7%E3%81%99%E3%80%82B.MBDSR2%20%3D%203%3B%2F*%20R2%20%E3%81%AE%20MB%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%2064%20%E3%83%90%E3%82%A4%E3%83%88%20*%2F%3C%2FP%3E%3CP%3ECAN_0.CBT.R%20%3D%200x80242844%3B%2F*%20%E3%83%93%E3%83%83%E3%83%88%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%20*%2F%3CBR%20%2F%3ECAN_0.FDCBT.R%20%3D%200x001614C6%3B%2F*%20%E3%83%93%E3%83%83%E3%83%88%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%20*%2F%3CBR%20%2F%3E%23endif%3CBR%20%2F%3Efor%20(%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D0%3B%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%26lt%3B96%3B%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%2B%2B)%3CBR%20%2F%3E%7B%3CBR%20%2F%3ECAN_0.RXIMR%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5DR%20%3D%200x1FFFFFFF%3B%2F*%20RX%20Individual%20Mask%20%E3%81%AF%E3%80%81MB%20ID%20%E3%82%92%E6%8C%81%E3%81%A4%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3ECAN_0.RXIMR%5B45%5D%E3%80%82R%20%3D%200%3B%2F*%20MB%2045%20TX%E3%81%AB%E4%BD%BF%E7%94%A8%20*%2F%3C%2FP%3E%3CP%3E%2F*%20MB45%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%20-%20%E9%80%81%E4%BF%A1%E5%AE%8C%E4%BA%86%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20*%2F%3CBR%20%2F%3ECAN_0.IMASK2%E3%81%A7%E3%81%99%E3%80%82R%20%7C%3D%201U%20%26lt%3B%26lt%3B%2013U%3B%3C%2FP%3E%3CP%3ECan_InitCAN0RxMsgBuffers%20()%3B%3C%2FP%3E%3CP%3ECAN_0.RXMGMASK.R%20%3D%200x1FFFFFFF%3B%3C%2FP%3E%3CP%3EINTC.PSR%5B568%5D.B.PRC_SELN%20%3D%200x8%3B%3CBR%20%2F%3EINTC.PSR%5B568%5D.B.PRIN%20%3D%2012%3B%3C%2FP%3E%3CP%3EINTC.PSR%5B569%5D.B.PRC_SELN%20%3D%200x8%3B%3CBR%20%2F%3EINTC.PSR%5B569%5D.B.PRIN%20%3D%2012%3B%3C%2FP%3E%3CP%3EINTC.PSR%5B570%5D.B.PRC_SELN%20%3D%200x8%3B%3CBR%20%2F%3EINTC.PSR%5B570%5D.B.PRIN%20%3D%2012%3B%3C%2FP%3E%3CP%3EINTC.PSR%5B571%5D.B.PRC_SELN%20%3D%200x8%3B%3CBR%20%2F%3EINTC.PSR%5B571%5D.B.PRIN%20%3D%2012%3B%3C%2FP%3E%3CP%3EINTC.PSR%5B572%5D.B.PRC_SELN%20%3D%200x8%3B%3CBR%20%2F%3EINTC.PSR%5B572%5D.B.PRIN%20%3D%2012%3B%3C%2FP%3E%3CP%3EINTC.PSR%5B573%5D.B.PRC_SELN%20%3D%200x8%3B%3CBR%20%2F%3EINTC.PSR%5B573%5D.B.PRIN%20%3D%2012%3B%3C%2FP%3E%3CP%3ECan0PortInit%20()%3B%3C%2FP%3E%3CP%3E%2F*CAN_0.CTRL2.R%20%7C%3D%200x00001000u%3BISOCANFD%20%E5%AF%BE%E5%BF%9C*%2F%3C%2FP%3E%3CP%3ECAN_0.IFLAG1.R%20%3D%200xFFFFFFFFU%3B%3CBR%20%2F%3ECAN_0.IFLAG2.R%20%3D%200xFFFFFFFFU%3B%3C%2FP%3E%3CP%3E%2F*%20FlexCAN%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%20*%2F%3CBR%20%2F%3ECAN_0.MCR%E3%81%A7%E3%81%99%E3%80%82R%20%26amp%3B%3D%20~(CAN_MCR_FRZ%20%7CCAN_MCR_HALT)%3B%3C%2FP%3E%3CP%3E%E4%B8%80%E6%96%B9(CAN_0.MCR.B.FRZACK%20%26amp%3B%20CAN_0.MCR.B.NOTRDY)%20%7B%7D%20%2F*%20%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E5%BE%85%E3%81%A4%20*%2F%3CBR%20%2F%3E%2F*%20%E8%89%AF%E3%81%84%E6%96%B9%E6%B3%95%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E9%96%8B%E5%A7%8B%2F%E7%B5%82%E4%BA%86%E6%99%82%E3%81%AB%20FRZACK%20%E3%82%92%E5%BE%85%E3%81%A4%20*%2F%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%3CU%3E%3CSTRONG%3E2.4MB%E3%81%AECAN%20ISR%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FP%3E%3CP%3Evoid%20Can_MsgBuf0003ISR%20(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Euint8%20Channel%3B%3CBR%20%2F%3Euint8%20ReturnValue%20%3D%200U%3B%3CBR%20%2F%3Euint32%20RegValue%3B%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%3D%200U%3B%3C%2FP%3E%3CP%3Eif%20(0U%20!%3D%20(CAN_0.IFLAG1.R%26amp%3B(1U%26lt%3B%26lt%3B%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D%E3%80%82MB)))%3CBR%20%2F%3E%7B%3CBR%20%2F%3EReturnValue%20%7C%3D%20Can_RxMsg%20(%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%2C%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%5D.MsgPtr)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%3D%201U%3B%3CBR%20%2F%3Eif%20(0U%20!%3D%20(CAN_0.IFLAG1.R%26amp%3B(1U%26lt%3B%26lt%3B%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D%E3%80%82MB)))%3CBR%20%2F%3E%7B%3CBR%20%2F%3EReturnValue%20%7C%3D%20Can_RxMsg%20(%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%2C%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%5D.MsgPtr)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%3D%202U%3B%3CBR%20%2F%3Eif%20(0U%20!%3D%20(CAN_0.IFLAG1.R%26amp%3B(1U%26lt%3B%26lt%3B%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D%E3%80%82MB)))%3CBR%20%2F%3E%7B%3CBR%20%2F%3EReturnValue%20%7C%3D%20Can_RxMsg%20(%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%2C%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%5D.MsgPtr)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%3D%203U%3B%3CBR%20%2F%3Eif%20(0U%20!%3D%20(CAN_0.IFLAG1.R%26amp%3B(1U%26lt%3B%26lt%3B%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D%E3%80%82MB)))%3CBR%20%2F%3E%7B%3CBR%20%2F%3EReturnValue%20%7C%3D%20Can_RxMsg%20(%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%2C%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%5D.MsgPtr)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%3CU%3E%3CSTRONG%3E3.%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E5%88%9D%E6%9C%9F%E5%8C%96%E6%A9%9F%E8%83%BD%3A%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FP%3E%3CP%3Evoid%20Can_InitCAN0RxMsgBuffers%20(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Euint8%20MsgIndex%3B%3CBR%20%2F%3Euint32%20StandardID%3B%3C%2FP%3E%3CP%3Efor%20(MsgIndex%3D0%3BMsgIndex%20%26lt%3B%20NUM_OF_RX_MSGS%3BMsgIndex%2B%2B)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EStandardID%20%3D%20Can_RxMsgBufConfig%5BMsgIndex%5D.%E6%A8%99%E6%BA%96%20ID%3B%3C%2FP%3E%3CP%3E*((uint32%20*)(CAN0_BASE_REG_ADDR%20%2B%20Can_RxMsgBufConfig%5BMsgIndex%5D.MBAddrOffset))%20%3D%20MB_CS_SET_EDL%20%7CMB_CS_SET_BRS%20%7CMB_CS_CODE_INACTIVE%20%7CMB_CS_STD_IDE%3B%3C%2FP%3E%3CP%3E*((uint32%20*)(CAN0_BASE_REG_ADDR%20%2B%20Can_RxMsgBufConfig%5BMsgIndex%5D.MBAddrOffset%20%2B%204U))%20%3D%20MB_STD_ID%20%26amp%3B%20(StandardID%20%26lt%3B%26lt%3B%2018)%3B%3C%2FP%3E%3CP%3E*((uint32%20*)(CAN0_BASE_REG_ADDR%20%2B%20Can_RxMsgBufConfig%5BMsgIndex%5D.MBAddrOffset))%20%7C%3D%20MB_CS_CODE_EMPTY%3B%3C%2FP%3E%3CP%3Eif%20(Can_RxMsgBufConfig%5BMsgIndex%5D.MB%20%26lt%3B%2032U)%3CBR%20%2F%3E%7B%3CBR%20%2F%3ECAN_0.IMASK1.R%20%7C%3D%201%20%26lt%3B%26lt%3B%20Can_RxMsgBufConfig%5BMsgIndex%5D.MB%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eelse%3CBR%20%2F%3E%7B%3CBR%20%2F%3ECAN_0.IMASK2.R%20%7C%3D%201%20%26lt%3B%26lt%3B%20(Can_RxMsgBufConfig%5BMsgIndex%5D.MB%20-%2032U)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%3CSTRONG%3E4.Receive_Msg()%20%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Euint8%20Can_RxMsg%20(uint8%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%80%81Can_MsgType%20*%20msg)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Euint32%20IFlag%3B%3CBR%20%2F%3Euint8%20*P8CAN0RxMBData%3B%3CBR%20%2F%3Euint8%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3B%3CBR%20%2F%3Euint8%20%E6%88%BB%E3%82%8A%E5%80%A4%20%3D%200U%3B%3C%2FP%3E%3CP%3Eif%20(%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%26lt%3B%20NUM_OF_RX_MSGS)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Eif%20(Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D.MB%20%26lt%3B%2032U)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EIFlag%20%3D%20CAN_0.IFLAG1%20%E3%81%A7%E3%81%99%E3%80%82R%26amp%3B(1U%26lt%3B%26lt%3B%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D%E3%80%82MB)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%E7%84%B6%E3%82%82%E7%84%A1%E3%81%8F%E3%81%B0%3CBR%20%2F%3E%7B%3CBR%20%2F%3EIFlag%20%3D%20CAN_0.IFLAG2%20%E3%81%A7%E3%81%99%E3%80%82R%26amp%3B(1U%26lt%3B%26lt%3B(Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D%E3%80%82MB%20-%2032U))%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3Eif%20(0U%20!%3D%20IFlag)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EMsg-%26gt%3BStdID%20%3D%20((*((uint32%20*)(CAN0_BASE_REG_ADDR%20%2B%20Can_RxMsgBufConfig%5BChannel%5D.MBAddrOffset%20%2B%204U)))%20%26amp%3B%20MB_STD_ID)%20%26gt%3B%26gt%3B%2018%3B%3C%2FP%3E%3CP%3EMsg-%26gt%3BDLC%20%3D%20((*((uint32%20*)(CAN0_BASE_REG_ADDR%20%2B%20Can_RxMsgBufConfig%5BChannel%5D.MBAddrOffset)))%20%26amp%3B%20MB_CS_DLC)%20%26gt%3B%26gt%3B%2016%3B%3C%2FP%3E%3CP%3EMsg-%26gt%3BNoOfBytes%20%3D%20Can_CalcNoOfBytes%20(Msg-%26gt%3BDLC)%3B%3C%2FP%3E%3CP%3EP8CAN0RxMB%E3%83%87%E3%83%BC%E3%82%BF%20%3D%20(uint8%20*)%20(CAN0_BASE_REG_ADDR%20%2B%20Can_RxMsgBufConfig%5BChannel%5D.MBAddrOffset%20%2B%208U)%3B%3C%2FP%3E%3CP%3Efor%20(%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D0%3B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%26lt%3B%20Msg-%26gt%3BNoOfBytes%3B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%2B%2B)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Emsg-%26gt%3Bpayload%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D%20%3D%20*(P8CAN0RxMBData%20%2B%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9)%3B%2F*%20%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%20*%2F%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Eif%20(Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D.MB%20%26lt%3B%2032U)%3CBR%20%2F%3E%7B%3CBR%20%2F%3ECAN_0.IFLAG1%20%E3%81%A7%E3%81%99%E3%80%82R%20%3D%20(1U%20%26lt%3B%26lt%3B%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D.MB)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%E7%84%B6%E3%82%82%E7%84%A1%E3%81%8F%E3%81%B0%3CBR%20%2F%3E%7B%3CBR%20%2F%3ECAN_0.IFLAG2.R%20%3D%20(1U%20%26lt%3B%26lt%3B%20(Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D.MB%20-%2032U))%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3ELED_DS7%20%3D%20~LED_DS7%3B%3C%2FP%3E%3CP%3EMsg-%26gt%3BMsgRcvd%2B%2B%3B%3C%2FP%3E%3CP%3EReturnValue%20%3D%201U%3B%3C%2FP%3E%3CP%3ECAN_0.IFLAG1.R%20%3D%200xFFFFFFFFU%3B%3CBR%20%2F%3ECAN_0.IFLAG2.R%20%3D%200xFFFFFFFFU%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E6%88%BB%E3%82%8A%E5%80%A4%20(ReturnValue)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%3CSTRONG%3E5.%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E6%A9%9F%E8%83%BD%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%AF%E8%A7%A3%E9%99%A4%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Evoid%20Can_UnMaskInterrupt%20(uint8%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%80%81uint32%20RegValue)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Euint8%20IntrID%20%3D%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%5D%E3%80%82%E3%82%A4%E3%83%B3%E3%83%88%E3%83%AAID%3B%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81(IntrID)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%E3%82%B1%E3%83%BC%E3%82%B90U%3ACAN_0.IMASK1%E3%80%82R%20%3D%20RegValue%3B%3CBR%20%2F%3E%E5%A3%8A%E3%81%99%3B%3C%2FP%3E%3CP%3Ecase%201U%20%3A%20CAN_0.IMASK1.R%20%3D%20RegValue%3B%3CBR%20%2F%3Ebreak%3B%3C%2FP%3E%3CP%3Ecase%202U%20%3A%20CAN_0.IMASK1.R%20%3D%20RegValue%3B%3CBR%20%2F%3Ebreak%3B%3C%2FP%3E%3CP%3Ecase%203U%20%3A%20CAN_0.IMASK1.R%20%3D%20RegValue%3B%3CBR%20%2F%3Ebreak%3B%3C%2FP%3E%3CP%3Ecase%204U%20%3A%20CAN_0.IMASK1.R%20%3D%20RegValue%3B%3CBR%20%2F%3Ebreak%3B%3C%2FP%3E%3CP%3Ecase%205U%20%3A%20CAN_0.IMASK2.R%20%3D%20RegValue%3B%3CBR%20%2F%3Ebreak%3B%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20%3A%20break%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%3CSTRONG%3E6.%E3%83%9E%E3%82%B9%E3%82%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E6%A9%9F%E8%83%BD%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Euint32%20Can_MaskInterrupt%20(uint8%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Euint32%20RegValue%3B%3CBR%20%2F%3Euint8%20IntrID%20%3D%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%5D%E3%80%82%E3%82%A4%E3%83%B3%E3%83%88%E3%83%AAID%3B%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81(IntrID)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Ecase%200U%20%3A%20RegValue%20%3D%20CAN_0.IMASK1.R%3B%3CBR%20%2F%3ECAN_0.IMASK1%E3%81%A7%E3%81%99%E3%80%82R%20%26amp%3B%3D%200xFFFFFFF0U%3B%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%200-3%3CBR%20%2F%3E%E5%A3%8A%E3%81%99%3B%3C%2FP%3E%3CP%3E%E3%82%B1%E3%83%BC%E3%82%B91U%3ARegValue%20%3D%20CAN_0.IMASK1%E3%80%82R%3B%3CBR%20%2F%3ECAN_0.IMASK1%E3%81%A7%E3%81%99%E3%80%82R%20%26amp%3B%3D%200xFFFFFF0FU%3BMB%204-7%3CBR%20%2F%3E%E5%A3%8A%E3%81%99%3B%3C%2FP%3E%3CP%3Ecase%202U%20%3A%20RegValue%20%3D%20CAN_0.IMASK1.R%3B%3CBR%20%2F%3ECAN_0.IMASK1.R%20%26amp%3B%3D%200xFFFFF0FFU%3B%20%2F%2F%20MB%208-11%3CBR%20%2F%3Ebreak%3B%3C%2FP%3E%3CP%3E%E3%82%B1%E3%83%BC%E3%82%B93U%3ARegValue%20%3D%20CAN_0.IMASK1%E3%80%82R%3B%3CBR%20%2F%3ECAN_0.IMASK1%E3%81%A7%E3%81%99%E3%80%82R%20%26amp%3B%3D%200xFFFF0FFFU%3B%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%8812-15%3CBR%20%2F%3E%E5%A3%8A%E3%81%99%3B%3C%2FP%3E%3CP%3Ecase%204U%20%3A%20RegValue%20%3D%20CAN_0.IMASK1.R%3B%3CBR%20%2F%3ECAN_0.IMASK1.R%20%26amp%3B%3D%200x0000FFFFU%3B%20%2F%2F%20MB%2016%20-%2031%3CBR%20%2F%3Ebreak%3B%3C%2FP%3E%3CP%3Ecase%205U%20%3A%20RegValue%20%3D%20CAN_0.IMASK2.R%3B%3CBR%20%2F%3ECAN_0.IMASK2%E3%81%A7%E3%81%99%E3%80%82R%20%26amp%3B%3D%200x00000000U%3B%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%8832%2B...TX%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8BMB%2045%E3%82%92%E5%90%AB%E3%82%80%3CBR%20%2F%3E%E5%A3%8A%E3%81%99%3B%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20%3A%20break%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3Ereturn%20RegValue%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%AE%E3%81%AA%E3%81%84CAN%E5%8F%97%E4%BF%A1%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%84%E3%82%84%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E5%BE%8C%E3%81%AB%E5%8B%95%E4%BD%9C%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%AE%E3%81%AA%E3%81%84CAN%E5%8F%97%E4%BF%A1%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%0A%3CP%3Euint8%20Can_RxMsg%20(uint8%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%80%81Can_MsgType%20*%20msg)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Euint32%20IFlag%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%3B%3CBR%20%2F%3Euint8%20*P8CAN0RxMBData%3B%3CBR%20%2F%3Euint8%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3B%3CBR%20%2F%3Euint8%20%E6%88%BB%E3%82%8A%E5%80%A4%20%3D%200U%3B%3C%2FP%3E%0A%3CP%3Eif%20(%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%26lt%3B%20NUM_OF_RX_MSGS)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Eif%20(Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D.MB%20%26lt%3B%2032U)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EIFlag%20%3D%20CAN_0.IFLAG1%20%E3%81%A7%E3%81%99%E3%80%82R%26amp%3B(1U%26lt%3B%26lt%3B%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D%E3%80%82MB)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%E7%84%B6%E3%82%82%E7%84%A1%E3%81%8F%E3%81%B0%3CBR%20%2F%3E%7B%3CBR%20%2F%3EIFlag%20%3D%20CAN_0.IFLAG2%20%E3%81%A7%E3%81%99%E3%80%82R%26amp%3B(1U%26lt%3B%26lt%3B(Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D%E3%80%82MB%20-%2032U))%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%0A%3CP%3Eif%20(0U%20!%3D%20IFlag)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EMsg-%26gt%3BStdID%20%3D%20((*((uint32%20*)(CAN0_BASE_REG_ADDR%20%2B%20Can_RxMsgBufConfig%5BChannel%5D.MBAddrOffset%20%2B%204U)))%20%26amp%3B%20MB_STD_ID)%20%26gt%3B%26gt%3B%2018%3B%3C%2FP%3E%0A%3CP%3EMsg-%26gt%3BDLC%20%3D%20((*((uint32%20*)(CAN0_BASE_REG_ADDR%20%2B%20Can_RxMsgBufConfig%5BChannel%5D.MBAddrOffset)))%20%26amp%3B%20MB_CS_DLC)%20%26gt%3B%26gt%3B%2016%3B%3C%2FP%3E%0A%3CP%3EMsg-%26gt%3BNoOfBytes%20%3D%20Can_CalcNoOfBytes%20(Msg-%26gt%3BDLC)%3B%3C%2FP%3E%0A%3CP%3EP8CAN0RxMB%E3%83%87%E3%83%BC%E3%82%BF%20%3D%20(uint8%20*)%20(CAN0_BASE_REG_ADDR%20%2B%20Can_RxMsgBufConfig%5BChannel%5D.MBAddrOffset%20%2B%208U)%3B%3C%2FP%3E%0A%3CP%3Efor%20(%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D0%3B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%26lt%3B%20Msg-%26gt%3BNoOfBytes%3B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%2B%2B)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Emsg-%26gt%3Bpayload%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D%20%3D%20*(P8CAN0RxMBData%20%2B%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9)%3B%2F*%20%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%20*%2F%3CBR%20%2F%3E%7D%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3Eif%20(Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D.MB%20%26lt%3B%2032U)%3CBR%20%2F%3E%7B%3CBR%20%2F%3ECAN_0.IFLAG1%20%E3%81%A7%E3%81%99%E3%80%82R%20%3D%20(1U%20%26lt%3B%26lt%3B%20Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D.MB)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%E7%84%B6%E3%82%82%E7%84%A1%E3%81%8F%E3%81%B0%3CBR%20%2F%3E%7B%3CBR%20%2F%3ECAN_0.IFLAG2.R%20%3D%20(1U%20%26lt%3B%26lt%3B%20(Can_RxMsgBufConfig%5B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%5D.MB%20-%2032U))%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%9F%E3%83%BC%20%3D%20CAN_0.TIMER%20%E3%81%A7%E3%81%99%E3%80%82R%3B%20%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%81%ABMB%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%3C%2FP%3E%0A%3CP%3ELED_DS7%20%3D%20~LED_DS7%3B%3C%2FP%3E%0A%3CP%3EMsg-%26gt%3BMsgRcvd%2B%2B%3B%3C%2FP%3E%0A%3CP%3EReturnValue%20%3D%201U%3B%3C%2FP%3E%0A%3CP%3E%2F%2FCAN_0.IFLAG1.R%20%3D%200xFFFFFFFFU%3B%3CBR%20%2F%3E%2F%2FCAN_0.IFLAG2.R%20%3D%200xFFFFFFFFU%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%0A%3CP%3E%E6%88%BB%E3%82%8A%E5%80%A4%20(ReturnValue)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%AE%E3%81%AA%E3%81%84CAN%E5%8F%97%E4%BF%A1%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMB%E3%81%AE%E5%BE%8C%E3%81%AECAN_TIMER%E3%81%AE%E8%AA%AD%E3%81%BF%E6%96%B9%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%AE%E3%81%AA%E3%81%84CAN%E5%8F%97%E4%BF%A1%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%9A%E3%83%88%E3%83%AB%E3%80%81%3CBR%20%2F%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%E8%A6%81%E4%BB%B6%3A%E5%90%84ISR%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8F%97%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%92%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%9D%E3%81%AE%E9%9D%9E%E5%B8%B8%E3%81%AB%E7%B7%8A%E6%80%A5%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%AE%E3%81%AA%E3%81%84CAN%E5%8F%97%E4%BF%A1%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E5%8B%95%E4%BD%9C%E3%81%AF%E3%80%81MB%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%82%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82MB%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AEControl%26amp%3BStatus%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A8%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%83%A9%E3%83%B3%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%8B%E3%80%81%E5%88%A5%E3%81%AEMB%E3%81%AECS%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A8%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E8%A7%A3%E9%99%A4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82MB%E3%81%8C%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%80%81%E7%84%A1%E6%96%99%E3%81%A7%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E7%AC%AC43.5.7.3%E7%AB%A0%E3%80%8C%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%81%ABMB%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81CAN_TIMER%E3%83%AA%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81MB%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E6%96%B0%E3%81%97%E3%81%84%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%A6%B3%E5%AF%9F3%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81MB%E3%81%8C%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8ACAN_TIMER%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%20%3CSPAN%3ECan_RxMsg%E6%A9%9F%E8%83%BD%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6%20%3CSPAN%3E%E3%80%81CAN_0.IFLAG1%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82R%20%3D%200xFFFFFFFFU%3B%3C%2FSPAN%3E%3CSPAN%3ECAN_0.IFLAG2.R%20%3D%200xFFFFFFFFU%3B%E8%A1%8C%E3%81%AF%E3%80%81%E4%BB%96%E3%81%AE%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%83%A9%E3%82%B0%E3%82%82%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E6%B8%88%E3%81%BFMB%E3%81%AE%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AE%E3%81%BF%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%2C%20Petr%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
