In FreeRTOS, while executing the tasks, automatically it is going to WKPU ISR and remain in ISR only
2,596 次查看
priya_p
In FreeRTOS, I am using 2 tasks which need RTC. For 1st task it is executing smoothly, but for second task it is triggering WKPU ISR and stuck in ISR only. Why it is happening so?
标记 (5)
7 回复数
2,581 次查看
PetrS
try if increasing heap will help.
BR, Petr
2,578 次查看
priya_p
already tried, still not working.
2,572 次查看
PetrS
ok, so can you share your project?
Br, Petr
2,556 次查看
priya_p
I am attaching the sd card code, here also WKPU interrupt is triggered. Not able to understand why it is triggering.
2,543 次查看
PetrS
seems it is because you call printf before start scheduler. Try to comment those 2 lines and print within tasks.
Br, Petr
2,509 次查看
priya_p
Tried that one but not at all working. The uploaded code is not running on FreeRTOS. It's a code without freeRTOS component.
2,461 次查看
PetrS
the project you shared above is using FreeRTOS, and it worked on my side after doing modification I wrote.
If have different project try to share it too.
BR, Petr
