Getting started with MPC5777c
1,392 次查看
purushothamredd
I am want to start with MPC5777c microcontroller for the same planning to buy evolution board.
I am new to Freescale microcontrollers please suggest me which compiler and debugger do I need to use, please share example projects if you have
1,237 次查看
davidtosenovjan
I would recommend to see following fact sheet:
http://www.nxp.com/docs/en/fact-sheet/MPC5777CFS.pdf
Most commonly used compilers probably will be our S32 Design Studio or GreenHills MULTI:
S32 Design Studio IDE|NXP
https://www.ghs.com/products/MULTI_IDE.html
Debugging probes are being offered by third party providers. Along with recommendations from our website below you could also take a look on third party providers’ website:
http://www.lauterbach.com
http://www.pemicro.com
https://www.segger.com
https://www.pls-mc.com
http://www.isystem.com
Example codes you may find here:
https://community.nxp.com/docs/DOC-329623
