The message you are trying to access is permanently deleted.
Got hands on the MPC5775B BMS AND VCU REFERENCE DESIGN. Was trying to implement a basic project in it as a starting point.Saw this in one of the documents I got:
Now do we need both the debugger ? Can we not program this unit with the USB it came with ? Is it absolute necessity to get the CAN adapter too ?
Solved! Go to Solution.
Looking at the board itself, it does not have any open-SDA uC for programming via USB cable.
You will need standard JTAG programmed / debugger for programming this board.
Peter
