FCCU reset
FCCU reset
3,333件の閲覧回数
Dina_ayoub
when initializing the the FCCU, and injecting an error that is configured with disable EOUT signals. The Fccu reset instead of injecting the error.
Does anyone have any idea why does that happen?
5 返答(返信)
3,320件の閲覧回数
davidtosenovjan
Is there any other NCF fault configured for reset reaction? If yes, the device may be reset by FOSU.
3,316件の閲覧回数
Dina_ayoub
No, all the NCF faults are configured to no reset and disable EOUT signals.
3,296件の閲覧回数
davidtosenovjan
Actually what is used device? have you investigated RGM registers to check reset reason?
3,283件の閲覧回数
Dina_ayoub
I am using MP5744.
which register should I investigate?
3,269件の閲覧回数
davidtosenovjan
MC_RGM_DES and MC_RGM_FES.
Also I would point out following appnote:
https://www.nxp.com/docs/en/application-note/AN5284.pdf
