FCCU error 15,71 System RAM correctable error
1,593件の閲覧回数
shriraamsundara
When I try to download SBL into ram, it fails and then fccu error 15 occurs which is ram error when I see in the manual, Any suggestions on what the problem might be
タグ(3)
2 返答(返信)
1,513件の閲覧回数
petervlna
You have ECC single bit fault in RAM. This is not any issue as ECC mechanism can correct it automatically.
make sure your ram is correctly initialized before you use it.
Peter
1,513件の閲覧回数
davidtosenovjan
Could you please specify used MCU? Thanks
