How can I set dual conversion in ADC command list
alexanderhu
How can i initial the TCU?Is there any SW DEMO?
petervlna
I expect you are referring to CTU and not TCU as you are speaking about ADC command list.
Here is the explanation:
Select CMS and Channels which have to be converted in dual-conversion mode.
Make sure your ADC's are in CTU mode.
Peter
petervlna
Peter
alexanderhu
Thank you for your help,Pete.The datasheet(MPC5744PRM.pdf) is hard to read.
davidtosenovjan
Could you specify used device? Thanks
