ETPU Initialization Code Example MPC5777C
alexey_bezgodko
Hi!
Document MPC5777CRM.pdf downloaded from nxp.com contains reference to the "See Initialization Code Example." on page 1819, but this link is not workable. Where can I find referenced initialization code example?
Thanks!
davidtosenovjan
Hi, it is broken link as the section is not present in the manual. I think it is not supposed to be there at all and the link should be removed. I will report is as a documentation error. Thanks for highlighting of the issue.
If you want to see which code is was supposed to point to, you may take a look to different device manual, specifically section 24.7.2:
https://www.nxp.com/docs/en/reference-manual/MPC5644ARM.pdf
