TJA1100 auto polarity detect function
1,417件の閲覧回数
naoyuki_abe
Hello Community,
Now I'm using the TJA1100 for Ethernet PHY, which support Polarity detection function.
Is it possible to enable / disable intentionally by register setting ?
タグ(2)
1,332件の閲覧回数
petervlna
HI,
According to the datasheet TJA1100:
If the TJA1100 detects a polarity error in the Slave, it will correct it internally while setting the POLARITY_DETECT bit in the External status register.
So the polarity correction is done internally and you cannot disable this feature.
regards,
Peter
