Details about eMIOS
Details about eMIOS
4,373 次查看
natarajmani
Dear Friends,
     i am going to use MPC5674f on my Project ...i got some information from reference manual and App Note about eMIOS..what  i understood is eMios is a timer ,it will support counter,compare ,capture  and PWM module.....so what will be the difference between eMIOs and eMIOS200 ..what is the application..where can we use...give me some simple sample code for  all  eMIOS mode ( GPIO,SAIC,SAOC,IPWM,IPM,DAOC,PEA,PEC,QDEC,WPTA ,MC,MCB,OPWFM,OPWFMB ,OPWMC,OPWMCB,OPWM,OPWMB)..please do the needful as soon as possible
3,291 次查看
PetrS
I have uploaded simple OPWMB example on https://community.freescale.com/thread/357241
It is based on eMIOS example given in AN2865 (http://cache.freescale.com/files/32bit/doc/app_note/AN2865.pdf).
I believe you can create own code similarly for other eMIOS modes based on the individual mode description given in the RM.
Petr
3,291 次查看
natarajmani
thank you friend..give me some simple sample code for GPIO on eMIOS module..
