Can I  get  the UART using example on MPC5607B
1,157 次查看
spring236869
Can I  get  the example of UART  using  on MPC5607B ?
When  I use UART mode  on MPC5607B,  the stop bit is low ,why?
965 次查看
lukaszadrapa
this example uses UART:
Example MPC5604B PinToggleStationery CW210
And attached you will find next two sample codes.
All of them are written for MPC5604B but there are no differences in case of UART.
Lukas
