Can CMU initialisation be done in application?
1,451 次查看
kasi_lakshmiman
Why is it necessary to initialize CMU registers in Bootloader?. Is it technically possible to manage the initialisation within application or is there any restriction due to microcontroller that handles the initialisation must be done in bootloader?
Note: Microcontroller used is MPC5777C. Please help me by answering this.
Thank you.
1,359 次查看
kasi_lakshmiman
Does the same apply for PS15 Clock Configuration Register, LFAST Clock Configuration Register and Sigma – Delta Clock Configuration Register ?
1,357 次查看
lukaszadrapa
yes, still the same answer. Everything is up to your requirements.
Lukas
1,359 次查看
lukaszadrapa
this is application dependent. Microcontroller doesn't care if bootoader or user application is executed. There's no "bootloader mode" or something like that. Everything depends on your needs (on used safety norms/standards).
Lukas
