Bootloader [MPC5744P]
1,115件の閲覧回数
abdelrhman
I tried to flash the MPC5744P using CAN and I used a CAN case for that, and I configured both the pins and baud rate as required, but it didn't flash the file and I received the following message.
Are there any missing steps to flash the kit successfully using CAN ?
Is it the vector CAN case which is used to flash the kit ??
1,105件の閲覧回数
lukaszadrapa
