Boot Assist Module in MPc5674F
1,545件の閲覧回数
rajiilangovan
Hi friend,
          In BAm,what is meant by Booting from the development bus? When will be use these things? and difference between  EBI Configuration for Separate Address and Data Development Bus
Boot Mode and EBI Configuration for multiplexed Address and Data Development Bus Boot Mode. Kindly explain in detail.
1,365件の閲覧回数
davidtosenovjan
Development Bus is different name for External Bus. Basically there are four boot options:
1) Internal Flash Boot Mode
2) Serial Boot Mode
3) non-multiplexed EBI Boot Mode
4) multiplexed EBI Boot Mode
Option 3 or 4 you can use in case you have connected external FLASH memory to EBI and you want to run the code from this memory. However typical operating mode is option 1.
