5744 DEBUG
5744 DEBUG
1,895 次查看
海亭刘
hello:
Actually test the execution time of each statement so slowly. My sys clk is 200MHZ.
for example:
  void delay_rotor(UInt8 cycles)
      while(cycles--);
when cycles=1, this code need about 5us.
I don't know why!
 thanks !
1,864 次查看
petervlna
How do you measure execution time? Are you tracing instructions? or with scope or some timer?
I am not able to tell you where is the issue from your description. Could you be more specific please?
regards,
Peter
1,864 次查看
海亭刘
HELLO:
I test the gpio
