Example MPC5775K-UART_with_Interrupts S32DS_1.0
* Detailed Description:
* Application performs basic initialization, setup PLL to maximum allowed freq.,
* setup clock for peripherals,
* LINFlex UART mode transmit and receive with interrupts
* Test HW:         MPC5775K-356DS, MPC57xx Motherboard
* MCU:             PPC5775KMMY3A 0N38M
* Terminal:        19200-8-no parity-1 stop bit-no flow control on LINFlexD_0
* Fsys:            PLL0 266MHz
*                    Z4 Core 133MHz
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          internal_FLASH (debug mode, release mode)
* EVB connection:  J14.2 to P12.6 Connect LINFlexD_0 RXD to main RS232
*                  J13.2 to P12.7 Connect LINFlexD_0 TXD to main RS232
Comments
I am looking for a UART driver with Interrupt for MPC5748G micro but you have shared for MPC5775K.
Please provide the required project
My requirement: Transmit and receive 9 bytes of hex values as shown below.
TxBuffer[9] = {0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19}
URGENT!!: Please provide an example code for the MPC5748G EVB board with Tx & Rx interrupt for my requirement.
This change will be used in our production program (FORD OEM).
Please provide the procedure to test your example code
Please review my Uart7_Rx_Isr code below:
void Uart7_Rx_Isr (void)
    unsigned char Channel = 7U;
    unsigned char Data;
    if (1 == LINFlexD_7.UARTSR.B.DRFRFE)
        Data = LINFlexD_7.BDRM.B.DATA4;
        LINFlexD_7.UARTSR.R &= UART_DRFRFE;      /* Clear data reception flag W1C */
       /*Save received data*/
       if (BufferTxdisplay_index < UART_7_TX_MAX_LENGTH)   //0 <12
           BufferTxdisplay[BufferTxdisplay_index] = Data;
           BufferTxdisplay_index++;
     if( (BufferTxdisplay_index >= 9) )
        BufferTxdisplay_index = 0;
I am attempting to read all 9 bytes using the above Rx ISR, but I am only receiving the first byte repeatedly, which is 0x11.
Expected Output:
TxBuffer[9] = {0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19};
RxBuffer[9] = {0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19};
Actual Output:
RxBuffer[9] = {0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11};
Could you please suggest what the issue is in the RxISR routine?
Please provide the correct Uart7_Rx_Isr routine to read valid 9 bytes and Uart7_Tx_Isr and Transmit function as well.
Please provide the procedure to test your code
%3CLINGO-SUB%20id%3D%22lingo-sub-1105794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Application%20performs%20basic%20initialization%2C%20setup%20PLL%20to%20maximum%20allowed%20freq.%2C%3C%2FP%3E%3CP%3E*%20setup%20clock%20for%20peripherals%2C%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20LINFlex%20UART%20mode%20transmit%20and%20receive%20with%20interrupts%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5775K-356DS%2C%20MPC57xx%20Motherboard%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5775KMMY3A%200N38M%3C%2FP%3E%3CP%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20LINFlexD_0%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PLL0%20266MHz%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Z4%20Core%20133MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20internal_FLASH%20(debug%20mode%2C%20release%20mode)%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%26nbsp%3B%20J14.2%20to%20P12.6%20Connect%20LINFlexD_0%20RXD%20to%20main%20RS232%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20J13.2%20to%20P12.7%20Connect%20LINFlexD_0%20TXD%20to%20main%20RS232%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1105794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Application%20performs%20basic%20initialization%2C%20setup%20PLL%20to%20maximum%20allowed%20freq.%2C%3C%2FP%3E%3CP%3E*%20setup%20clock%20for%20peripherals%2C%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20LINFlex%20UART%20mode%20transmit%20and%20receive%20with%20interrupts%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5775K-356DS%2C%20MPC57xx%20Motherboard%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5775KMMY3A%200N38M%3C%2FP%3E%3CP%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20LINFlexD_0%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PLL0%20266MHz%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Z4%20Core%20133MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20internal_FLASH%20(debug%20mode%2C%20release%20mode)%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%26nbsp%3B%20J14.2%20to%20P12.6%20Connect%20LINFlexD_0%20RXD%20to%20main%20RS232%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20J13.2%20to%20P12.7%20Connect%20LINFlexD_0%20TXD%20to%20main%20RS232%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1105794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20provide%20the%20procedure%20to%20test%20your%20code%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20review%20my%26nbsp%3BUart7_Rx_Isr%20code%20below%3A%3C%2FP%3E%3CDIV%3Evoid%20Uart7_Rx_Isr%20(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20unsigned%20char%20Channel%20%3D%207U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20unsigned%20char%20Data%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20if%20(1%20%3D%3D%20LINFlexD_7.UARTSR.B.DRFRFE)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Data%20%3D%20LINFlexD_7.BDRM.B.DATA4%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20LINFlexD_7.UARTSR.R%20%26amp%3B%3D%20UART_DRFRFE%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%2F*%20Clear%20data%20reception%20flag%20W1C%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%2F*Save%20received%20data*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bif%20(BufferTxdisplay_index%20%26lt%3B%20UART_7_TX_MAX_LENGTH)%26nbsp%3B%20%26nbsp%3B%2F%2F0%20%26lt%3B12%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BBufferTxdisplay%5BBufferTxdisplay_index%5D%20%3D%20Data%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BBufferTxdisplay_index%2B%2B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bif(%20(BufferTxdisplay_index%20%26gt%3B%3D%209)%20)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20BufferTxdisplay_index%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EI%20am%20attempting%20to%20read%20all%209%20bytes%20using%20the%20above%20Rx%20ISR%2C%20but%20I%20am%20only%20receiving%20the%20first%20byte%20repeatedly%2C%20which%20is%200x11.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EExpected%20Output%3A%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ETxBuffer%5B9%5D%20%3D%20%7B0x11%2C%200x12%2C%200x13%2C%200x14%2C%200x15%2C%200x16%2C%200x17%2C%200x18%2C%200x19%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ERxBuffer%5B9%5D%20%3D%20%7B0x11%2C%200x12%2C%200x13%2C%200x14%2C%200x15%2C%200x16%2C%200x17%2C%200x18%2C%200x19%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EActual%20Output%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3ETxBuffer%5B9%5D%20%3D%20%7B0x11%2C%200x12%2C%200x13%2C%200x14%2C%200x15%2C%200x16%2C%200x17%2C%200x18%2C%200x19%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ERxBuffer%5B9%5D%20%3D%20%7B0x11%2C%200x11%2C%200x11%2C%200x11%2C%200x11%2C%200x11%2C%200x11%2C%200x11%2C%200x11%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECould%20you%20please%20suggest%20what%20the%20issue%20is%20in%20the%20RxISR%20routine%3F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPlease%20provide%20the%20correct%26nbsp%3BUart7_Rx_Isr%20routine%20to%20read%20valid%209%20bytes%20and%20Uart7_Tx_Isr%20and%20Transmit%20function%20as%20well.%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20provide%20the%20procedure%20to%20test%20your%20example%20code%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMy%20requirement%3A%20Transmit%20and%20receive%209%20bytes%20of%20hex%20values%20as%20shown%20below.%3CBR%20%2F%3ETxBuffer%5B9%5D%20%3D%20%7B0x11%2C%200x12%2C%200x13%2C%200x14%2C%200x15%2C%200x16%2C%200x17%2C%200x18%2C%200x19%7D%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EURGENT!!%3A%20Please%20provide%20an%20example%20code%20for%20the%20MPC5748G%20EVB%20board%20with%20Tx%20%26amp%3B%20Rx%20interrupt%20for%20my%20requirement.%3CBR%20%2F%3EThis%20change%20will%20be%20used%20in%20our%20production%20program%20(FORD%20OEM).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1867956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1867956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20looking%20for%20a%20UART%20driver%20with%20Interrupt%20for%20MPC5748G%20micro%20but%20you%20have%20shared%20for%20MPC5775K.%3C%2FP%3E%3CP%3EPlease%20provide%20the%20required%20project%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎02-12-2016 06:19 AM
Updated by:
