Example MPC5775K-UART_with_Interrupts S32DS_1.0
* Detailed Description:
* Application performs basic initialization, setup PLL to maximum allowed freq.,
* setup clock for peripherals,
* LINFlex UART mode transmit and receive with interrupts
* Test HW:         MPC5775K-356DS, MPC57xx Motherboard
* MCU:             PPC5775KMMY3A 0N38M
* Terminal:        19200-8-no parity-1 stop bit-no flow control on LINFlexD_0
* Fsys:            PLL0 266MHz
*                    Z4 Core 133MHz
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          internal_FLASH (debug mode, release mode)
* EVB connection:  J14.2 to P12.6 Connect LINFlexD_0 RXD to main RS232
*                  J13.2 to P12.7 Connect LINFlexD_0 TXD to main RS232
Comments
I am looking for a UART driver with Interrupt for MPC5748G micro but you have shared for MPC5775K.
Please provide the required project
My requirement: Transmit and receive 9 bytes of hex values as shown below.
TxBuffer[9] = {0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19}
URGENT!!: Please provide an example code for the MPC5748G EVB board with Tx & Rx interrupt for my requirement.
This change will be used in our production program (FORD OEM).
Please provide the procedure to test your example code
Please review my Uart7_Rx_Isr code below:
void Uart7_Rx_Isr (void)
    unsigned char Channel = 7U;
    unsigned char Data;
    if (1 == LINFlexD_7.UARTSR.B.DRFRFE)
        Data = LINFlexD_7.BDRM.B.DATA4;
        LINFlexD_7.UARTSR.R &= UART_DRFRFE;      /* Clear data reception flag W1C */
       /*Save received data*/
       if (BufferTxdisplay_index < UART_7_TX_MAX_LENGTH)   //0 <12
           BufferTxdisplay[BufferTxdisplay_index] = Data;
           BufferTxdisplay_index++;
     if( (BufferTxdisplay_index >= 9) )
        BufferTxdisplay_index = 0;
I am attempting to read all 9 bytes using the above Rx ISR, but I am only receiving the first byte repeatedly, which is 0x11.
Expected Output:
TxBuffer[9] = {0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19};
RxBuffer[9] = {0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19};
Actual Output:
RxBuffer[9] = {0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11};
Could you please suggest what the issue is in the RxISR routine?
Please provide the correct Uart7_Rx_Isr routine to read valid 9 bytes and Uart7_Tx_Isr and Transmit function as well.
Please provide the procedure to test your code
No ratings
Version history
Last update:
‎02-12-2016 06:19 AM
Updated by:
