Example MPC5554 eQADC+INTC Single Scan CW210
* Detailed Description:
* Initializes eQADC module, performs calibration and converts channel 0 and
* displays results into terminal window by interrupt service routine. Analog
* input AN[0] requires external connection to converted voltage (potentiometer).
* Test HW:        MPC5554EVB
* MCU:            MPC5554MVR132
* Fsys:           132/112/80/12 MHz
* Debugger:       Lauterbach Trace32
*                 PeMicro USB-ML-PPCNEXUS
* Target:         RAM, internal_FLASH
* Terminal:       19200-8-no parity-1 stop bit-no flow control on eSCI_A
* EVB connection: USER_DEV pin RV2(i.e. pin8) -> pin B7 on I/O header ring
*                 (potentiometer RV2 to analog input AN[0])
Comments
very good,thank you
Hello, I burned the program in this example into MPC5554evb, but I don’t know how to verify it. How can I test and verify this example on MPC5554evb?
%3CLINGO-SUB%20id%3D%22lingo-sub-1126361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5554%20eQADC%2BINTC%20Single%20Scan%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CPRE%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20Initializes%20eQADC%20module%2C%20performs%20calibration%20and%20converts%20channel%200%20and%3CBR%20%2F%3E*%20displays%20results%20into%20terminal%20window%20by%20interrupt%20service%20routine.%20Analog%3CBR%20%2F%3E*%20input%20AN%5B0%5D%20requires%20external%20connection%20to%20converted%20voltage%20(potentiometer).%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5554EVB%3CBR%20%2F%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5554MVR132%3CBR%20%2F%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132%2F112%2F80%2F12%20MHz%3CBR%20%2F%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3CBR%20%2F%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3CBR%20%2F%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3CBR%20%2F%3E*%20EVB%20connection%3A%20USER_DEV%20pin%20RV2(i.e.%20pin8)%20-%26gt%3B%20pin%20B7%20on%20I%2FO%20header%20ring%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(potentiometer%20RV2%20to%20analog%20input%20AN%5B0%5D)%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E*%3CBR%20%2F%3E********************************************************************************%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1126361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%0A%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%0A%3CP%3E*%20Initializes%20eQADC%20module%2C%20performs%20calibration%20and%20converts%20channel%200%20and%3C%2FP%3E%0A%3CP%3E*%20displays%20results%20into%20terminal%20window%20by%20interrupt%20service%20routine.%20Analog%3C%2FP%3E%0A%3CP%3E*%20input%20AN%5B0%5D%20requires%20external%20connection%20to%20converted%20voltage%20(potentiometer).%3C%2FP%3E%0A%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%0A%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5554EVB%3C%2FP%3E%0A%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5554MVR132%3C%2FP%3E%0A%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132%2F112%2F80%2F12%20MHz%3C%2FP%3E%0A%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%0A%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%0A%3CP%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3C%2FP%3E%0A%3CP%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3C%2FP%3E%0A%3CP%3E*%20EVB%20connection%3A%20USER_DEV%20pin%20RV2(i.e.%20pin8)%20-%26gt%3B%20pin%20B7%20on%20I%2FO%20header%20ring%3C%2FP%3E%0A%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(potentiometer%20RV2%20to%20analog%20input%20AN%5B0%5D)%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%3E*%3C%2FP%3E%0A%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1878110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20Example%20MPC5554%20eQADC%2BINTC%20Single%20Scan%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1878110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHello%2C%20I%20burned%20the%20program%20in%20this%20example%20into%20MPC5554evb%2C%20but%20I%20don%E2%80%99t%20know%20how%20to%20verify%20it.%20How%20can%20I%20test%20and%20verify%20this%20example%20on%20MPC5554evb%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5554%20eQADC%2BINTC%20Single%20Scan%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Every%20good%2Cthank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎11-16-2022 07:27 AM
Updated by:
