imx93 IA Models
imx93 IA Models
1,894 次查看
joya
I've a question about go-point application, I wonder how did you compress IA models , such as for object detection, I've a fine tuned model but very large and can't be fit into the imx93 board, any advice please?
1,782 次查看
joya
Hello, thank you for your response.
I tried to install the eIQ tool on my Linux machine version 24.04.2 but unfortunately it's doesn't work!
Is this tool compatible just with Linux 20.04  or with all Linux releases ? thank you.
1,758 次查看
Chavira
HI @joya!
Unfortunately eIQ Toolkit only works on Ubuntu 20
Best Regards!
Chavira
1,869 次查看
Chavira
HI @joya!
Thank you for contacting NXP Support!
You can refer to our i.MX Machine Learning User's Guide to learn about our BSP and how you can create your own models and deploy it in iMX93.
You can use the eIQ® Toolkit to train ML models.
Best Regards!
Chavira
